flashbsd said:so let me get this straight, you bypass the unit, but instead of using resistors, just leave the unit connected, and even though theres no pipes connected, it may still operate and not affect anything? I think ill do it this way![]()
Sim said:You may cover it, but not neccessary. If you use any kind of cap/cover make sure it is not clogged/closed completely, otherwise the combi valve (and wastegate on ibizas) will stay opened!
davidol said:yeah it'll still have the full effect, throttle response is greatly improved IMHO, i removed the tank however and then screwed the N249 valve to a bolt on the back of the rocker cover (saved me having to extend the wires) and then relocated the N112 valve to the scuttle panel.
Ive finally completed the loom
Proper AMP connections used, booted to stop damage.
The whole thing is braided and uses 8amp cable.
All joints are double heat shrinked, the whole thing is a metre long.
Need a little more vac pipe and make a bracket up to hold the solinoid in place in the scuttle and then I can write a proper guide.
And before anyone starts tapping out 'Can you make me one' - theyll set you back about 18 quid and thats cost price!
Hi guys,
i removed n249 valve and the news connections are these:
is this right? the check valve directions is right?
if i make a check with vagcom always appears the n249 mechanical malfunction.
I added the 30ohm resistor (i'm an electronics technician..)
and sometimes appears n112 error, incorrect flux detect.
(with check valve turn right or left..)
any suggestion?![]()
