ok so maf changed for a brand new oem and still no joy!
seems the requested boost vs the actual boost is the
problem, any ideas???
here is a newer log.
Tuesday 26 March 2013 17:11:26:10074 VCDS Version: Release 10.6.4 (x64) Data version: 20110418
06A 906 032 HJ ADVMB 1.8L R4/5VT 0002
G002 F0 G002 F1 G002 F2 G002 F3 G031 F0 G031 F1 G032 F0 G032 F1 G115 F2 G115
Marker TIME Group 2 - Field 0 TIME Group 2 - Field 1 TIME Group 2 - Field 2 TIME Group 2 - Field 3 TIME Group 31 - Field 0 TIME Group 31 - Field 1 TIME Group 32 - Field 0 TIME Group 32 - Field 1 TIME Group 115 - Field 2 TIME Group 115 - Field 3
STAMP Engine Speed - (G28) STAMP Engine Load STAMP Injection Timing STAMP Mass Air Flow - (G70) STAMP Lambda Control - Bank 1 (actual) STAMP Lambda Control - Bank 1 (specified) STAMP Adaptation (Idle) - Bank 1 Sensor 1 STAMP Adaptation (Partial) - Bank 1 Sensor 1 STAMP Boost Pressure - (specified) STAMP Boost Pressure - (actual)
/min % ms g/s % % mbar mbar
1.19 800 1.19 19.5 1.19 2.04 1.19 2.56 0.28 0.992 0.28 1 0.59 -0.8 0.59 0 0.89 1000 0.89 1010
2.5 1120 2.5 29.3 2.5 3.4 2.5 5.67 1.53 1 1.54 1 1.9 -0.8 1.9 0 2.19 1000 2.19 1010
3.85 880 3.85 40.6 3.85 4.76 3.85 8 2.9 0.938 2.9 1 3.21 -0.8 3.21 0 3.51 1000 3.51 1010
5.16 1240 5.16 36.8 5.16 3.74 5.16 7.89 4.21 1 4.21 1 4.5 -0.8 4.5 0 4.83 1000 4.83 1020
6.63 1640 6.63 36.1 6.63 4.08 6.63 11.89 5.52 0.992 5.52 1 5.92 -0.8 5.92 0 6.22 1000 6.22 1020
7.83 1920 7.83 21.8 7.83 2.38 7.83 7.94 6.93 1.008 6.93 1 7.23 -0.8 7.23 0 7.53 1000 7.53 1020
9.14 2000 9.14 22.6 9.14 2.38 9.14 8.53 8.13 0.992 8.13 1 8.44 -0.8 8.44 0 8.77 1000 8.77 1020
10.45 2080 10.45 21.8 10.45 2.38 10.45 8.58 9.44 0.984 9.44 1 9.74 -0.8 9.74 0 10.05 1000 10.05 1020
11.66 2080 11.66 19.5 11.66 2.38 11.66 7.97 10.75 1.008 10.75 1 11.05 -0.8 11.05 0 11.35 1000 11.35 1020
12.86 2120 12.86 24.8 12.86 2.72 12.86 10.19 11.96 1 11.96 1 12.26 -0.8 12.26 0 12.56 1000 12.56 1020
14.17 2200 14.17 13.5 14.17 1.7 14.17 5.61 13.16 0.992 13.16 1 13.57 -0.8 13.57 0 13.88 1000 13.88 1020
15.38 1720 15.38 13.5 15.38 1.7 15.38 4.5 14.47 1 14.47 1 14.77 -0.8 14.77 0 15.07 1000 15.07 1020
16.68 1400 16.68 24.1 16.68 4.08 16.68 10.14 15.68 1.008 15.68 1 15.98 -0.8 15.98 0 16.28 1000 16.28 1010
17.99 1280 17.99 16.5 17.99 2.38 17.99 6.5 16.99 0.883 16.99 1 17.29 -0.8 17.29 0 17.59 1000 17.59 1030
19.3 1480 19.3 79.7 19.3 8.84 19.3 23.61 18.29 0.86 18.29 1 18.59 -0.8 18.59 0 18.93 1370 18.93 1070
20.61 2240 20.61 106.8 20.61 12.24 20.61 49.67 19.6 0.984 19.6 1 19.92 -0.8 19.92 0 20.3 2230 20.3 1280
21.81 3360 21.81 169.9 21.81 20.74 21.81 112.11 20.91 0.938 20.91 0.922 21.21 -0.8 21.21 0 21.55 2550 21.55 1910
23.02 4680 23.02 154.9 23.02 19.04 23.02 136.22 22.11 0.852 22.11 0.86 22.42 -0.8 22.42 0 22.72 2550 22.72 2000
24.23 4880 24.23 11.3 24.23 1.7 24.23 8.61 23.36 0.828 23.36 0.821 23.63 -0.8 23.63 0 23.92 1000 23.92 1160
25.43 4280 25.43 11.3 25.43 0 25.43 9.78 24.53 0.836 24.53 1 24.83 -0.8 24.83 0 25.17 1000 25.17 1040
26.64 3480 26.64 12 26.64 0 26.64 8.28 25.73 1.991 25.73 1.047 26.04 -0.8 26.04 0 26.34 1000 26.34 1040
27.95 2560 27.95 13.5 27.95 0 27.95 6.78 26.94 1.991 26.94 1.047 27.34 -0.8 27.34 0 27.64 1000 27.64 1040
29.15 2520 29.15 27.1 29.15 3.74 29.15 13.61 28.29 1.991 28.29 1.047 28.55 -0.8 28.55 0 28.85 1000 28.85 1020
30.36 2640 30.36 30.8 30.36 4.08 30.36 17.75 29.46 0.821 29.46 1 29.76 -0.8 29.76 0 30.06 1000 30.06 1030
31.57 2960 31.57 75.2 31.57 8.5 31.57 46.94 30.66 0.992 30.66 1 30.96 -0.8 30.96 0 31.27 1020 31.27 1140
32.87 3960 32.87 156.4 32.87 17.34 32.87 125.39 31.87 1.008 31.87 1 32.21 -0.8 32.21 0 32.57 2550 32.57 1630
34.18 5280 34.18 138.3 34.18 17.68 34.18 141.53 33.18 0.984 33.18 1 33.58 -0.8 33.58 0 33.89 2420 33.89 1840
35.5 6320 35.5 122.6 35.5 15.64 35.5 146.78 34.52 0.821 34.52 0.844 34.82 -0.8 34.82 0 35.2 2250 35.2 1600
36.71 6920 36.71 98.5 36.71 11.9 36.71 123.39 35.83 0.805 35.83 0.821 36.1 -0.8 36.1 0 36.41 1460 36.41 1550
38.01 6200 38.01 12 38.01 0 38.01 14.31 37 0.828 37 0.883 37.31 -0.8 37.31 0 37.64 1000 37.64 1080
39.21 5080 39.21 12 39.21 0 39.21 12.61 38.31 1.991 38.31 1.047 38.61 -0.8 38.61 0 38.91 1000 38.91 1040
40.42 4080 40.42 12 40.42 0 40.42 10.14 39.51 1.991 39.51 1.047 39.81 -0.8 39.81 0 40.12 1000 40.12 1040
41.73 3760 41.73 12 41.73 0 41.73 9.17 40.72 1.991 40.72 1.047 41.12 -0.8 41.12 0 41.42 1000 41.42 1040
43.03 2600 43.03 12.8 43.03 2.04 43.03 6 42.03 1.991 42.03 1.047 42.43 -0.8 42.43 0 42.73 1000 42.73 1040
44.24 2520 44.24 12.8 44.24 2.04 44.24 6.22 43.33 0.883 43.33 0.797 43.64 -0.8 43.64 0 43.94 1000 43.94 1020
45.45 2440 45.45 12.8 45.45 2.04 45.45 6.19 44.54 0.782 44.54 0.797 44.84 -0.8 44.84 0 45.14 1000 45.14 1020
46.65 2360 46.65 12.8 46.65 1.7 46.65 5.97 45.75 0.797 45.75 0.797 46.05 -0.8 46.05 0 46.35 1000 46.35 1020
47.96 2520 47.96 101.5 47.96 12.24 47.96 54.94 46.95 1.008 46.95 1 47.29 -0.8 47.29 0 47.66 2550 47.66 1160
49.27 3160 49.27 166.2 49.27 19.72 49.27 102.67 48.26 0.992 48.26 1 48.66 -0.8 48.66 0 48.97 2550 48.97 2020
50.47 3840 50.47 168.4 50.47 21.42 50.47 124.47 49.57 0.891 49.57 0.883 49.89 -0.8 49.89 0 50.17 2550 50.17 2190
51.68 4480 51.68 156.4 51.68 20.06 51.68 132.39 50.78 0.813 50.78 0.821 51.08 -0.8 51.08 0 51.38 2550 51.38 2070
52.89 5040 52.89 146.6 52.89 18.7 52.89 139.39 51.98 0.797 51.98 0.821 52.29 -0.8 52.29 0 52.6 2500 52.6 1920
54.21 5560 54.21 136.8 54.21 17.34 54.21 143.19 53.19 0.797 53.19 0.821 53.53 -0.8 53.53 0 53.91 2410 53.91 1760
55.51 5960 55.51 128.6 55.51 16.66 55.51 146.78 54.6 0.805 54.6 0.821 54.91 -0.8 54.91 0 55.2 2360 55.2 1650
56.72 6320 56.72 122.6 56.72 15.98 56.72 147.25 55.84 0.813 55.84 0.821 56.11 -0.8 56.11 0 56.41 2340 56.41 1610
57.93 6600 57.93 116.5 57.93 15.98 57.93 149.67 57.02 0.805 57.02 0.813 57.32 -0.8 57.32 0 57.63 2320 57.63 1590
59.13 6840 59.13 113.5 59.13 15.3 59.13 148.78 58.22 0.758 58.22 0.758 58.53 -0.8 58.53 0 58.83 2280 58.83 1580
60.44 6600 60.44 9 60.44 1.36 60.44 10.42 59.44 0.782 59.44 0.766 59.83 -0.8 59.83 0 60.13 1000 60.13 1130
61.74 5760 61.74 12 61.74 0 61.74 13.28 60.73 1.991 60.73 1.047 61.14 -0.8 61.14 0 61.44 1000 61.44 1040
62.95 4840 62.95 12.8 62.95 0 62.95 12.08 62.08 1.991 62.08 1.047 62.34 -0.8 62.34 0 62.64 1000 62.64 1040
64.25 4000 64.25 12 64.25 0 64.25 9.69 63.25 1.991 63.25 1.047 63.55 -0.8 63.55 0 63.85 1000 63.85 1040
65.46 3400 65.46 12.8 65.46 0 65.46 8.47 64.56 1.991 64.56 1.047 64.87 -0.8 64.87 0 65.19 1000 65.19 1040
66.67 3000 66.67 12.8 66.67 0 66.67 7.58 65.76 1.991 65.76 1.047 66.06 -0.8 66.06 0 66.37 1000 66.37 1040
