Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
I'm so lucky to have this car, in 2005 I purchased the very last BAM 225 Leon off the production line in Spain, brought down to me from Barcelona. After over 10 years the clutch began to slip, I already had a few light mods done, d/v, BMC CDA and a remap, but this evening I just finished fitting a few mods over here in sunny Gibraltar. Mods such as: FMIC (Airtech), Tarox F2000's brakes front & rear, Tarox Strada pads front & rear. Upgraded the Milltek catback into a turbo back system with the large-bore downpipe and catalyst bypass assembly. Installed the complete Sachs SMF motor-sports kit, disc, pressure plate, lightened flywheel and uprated slave cylinder. Oh and a Quaife LSD!Just got back home an hour ago, so have been gentle
Next week, I will be hooking up my PLX kiwi 2 device to the OBD2 port and start logging some data! I am still waiting to sort out the braided brake lines, but the ones I receives had those banjo fittings and I received no bolts to adapt them for a good fit, so I'm in the process of having them replaced. Also, I need to replace my large TIP because yes, as it’s a left-hand drive car the larger TIP is hitting the brake master cylinder and causing some rubbing against the silicone of the TIP (I fear soon it will breach and cause a slight leak which will obviously not be good), so that will be replaced for a more adequately sized one. Also will be replacing the upper inter-cooler hoses, charge pipe, and d/v cold-side kit is also still to arrive and be fitted. Pictures were with my old phone, so apologies for the bad quality, but I'm also finding it difficult to attach the images to this message, so the images might not even be here! Anyway, I'm exhausted from working all day, so will try to add them again if not successful, at some stage tomorrow. . . (Im looking at the preview and still cant see my images or attach them, sorry I'm a rare forum poster so am a complete novice at attaching images for this arrgghh! lol. Nite nite.
Asfaik you can achieve 180bhp with just a remap on these so you should be looking at upward of that
Sent from my GT-I9195 using Tapatalk
Ah confusing it with the 1.9 PD, shameFidge it's a 1.9 tdi 8v engine code asv they Are 110bhp standard mate a remap your looking at 140-145 @ stage 1 I think you may be confusing it with the 2.0 tdi engine which is 140bhp standard and can be tuned to 180bhp with a stage 1![]()
Seat Leon 1.9tdi 110bhp ASV, BMC CDA,Egr delete, decat,
Any of the 1.9 PD they have better potential for remaps where 90/ 110/ 130 or 150 stockWhich 1.9 PD? There a several lol mine is ve not pd
