S17EW O
hi all i need to know if a set of 19inch Mod P Kazuki porsche rims will suit my LCR. and if they will fit 5x130 ET45 Fronts and 11.0x19" 5x130 ET52 Rears obviously with adaptors.....need some answers fast and aint got a clue and might be picking up in an hour!!!!dont know how to put pics or links but they are on ebay
Assuming you mean these, hard to tell without seeing them on the car.
Can't imagine they will look bad, but I do like the look of very straight spoked rims on the LCR.
well i have rs6 rims on as of now and they are a similar style......how much will they stick out do you think, im going to have to have 10, 15 or 20mm adaptors too. ive seen gthem on a shirocco in 20s so would have thought they would be ok but i could do with being sure and im not very good at this lol
I'd have thought the Scirocco's arches were quite a bit bigger than the LCR's
yeah i agree but then i no 19s will go on an LCR its just whether the width and et will cause a problem, do you think they will go on and clear brembos, and springs etc just stick out alittle past the arches, i never no how et works
I had ET56 OEM's on the S3 (18's), and changed them for 19's (comparative rolling profile). The car sits a tad higher, but it was the offset that made the difference.
The ET35 of the new 19's bought the wheels right out flush with the wheel arches so I get very occasional rubbing on the arch edges (rears) under full compression. No issues with the brakes or springs.
What is the ET of OEM LCR rims?
your asking me now, i really dont know, if i could find out do you think you could work out if they would fit....
i think they will look good, most 5 spoke wheels do in my opinion. you can always have your arches roller/flared to accept wider wheels. car will then look phat :D
not going fo rolled arches just need to know if theyll drop on without, im lowered about 20mm. really am strugling here
hi all just found out that porsche carerra s wheels are 11j on the back with an et of 67 and drop on an lcr fine so will these being 11j wide with an et of 52 be any good.....
looks like the rear will deffo foul the arches as they are et52, (warren cox 's wheels were et56 and rubbed) plus the fact that your are going to have to use wheel adaptors which'l push them out even more. bad news i'm afraid, unless i got my calculations wrong :redface:
yeah ive just had conformation they wont fit over the phone.......im also interested in some 19 carerra s wheels, like i said earlier
FRONTS: 8J x 19H2 x ET57
REARS: 11J x 19H2 x ET67
and i do believe theres someone on here running these im just not sure if they have had any arch rolling etc done!
Very much doubt 11j would fit on the rear well seriors stretch and camber even then may rub nick has 10.5j on his and has air ride it's in readers rides, all depends how much you want to spend making them fit
