Yes it certainlt does make for some interesting reading
I'm slowly building up the funds and should hopefullly be racking your brains about this shortley
Oh finally fitted a bracket for the rear seats and got the strutbrace powdercoated and fitted.
hey dude, saw you on the ringroad when i was working car still looks and sounds sweet, did consider turning round and catching you up to say hi, but id never had caught you :)
Few more pics from this weekends work
I've been working on a heatshield for the bulkhead seeing as i didn't really have anything there, decided to modify a LCR heatshield and see how it goes, it's still work in progress at the moment but it'll give you an idea
Also finished fitting centre console back together with the gauges in
Not bad mate! Did you just wrap the lambda and vems wires together in the silver tube?
I've still got to do something with the wires for the vems, not sure wether to heat wrap them or try and get them behind the heatshield which will envolve cutting it about a bit more
that looks good that heat sheild,and them gauges look awesom!whats the black one?
Black gauge is a vems air/fuel and exhaust gas temp gauge
Yeah, the original one goes behind the brake lines though so there's nothing shielding them, they did have a small alloy one from factory but thought i'd try and come up with something a bit bigger.
How good it will be only time will tell i guess
alloy one factory extra? my bulk head is abit of a mess...im in need of some part numbers or parts.... at the bottom of bulk head, drivers side there is a big black hose/ducting that houses some cable..maybe clutch cable and others...you got a spare one at all? or a part number..mine is so perished its unreal
found it
what you think?
Looks exactly like mine
The tinfoil looking one behind the new one is factory fit (atleast i think it was, maybe it's the 20vt one)
Do you mean the rubber boot that goes over the steering knuckle (that's the only bit i can think of)
