Looking on the cool mods for skint people thread explains where to fit the catch tank, people have different ideas, will pick what i think would be best and easiest
Well the poor car has been suffering from boost problems lately, So a kind member from here djhorace ran vag com on my car and i now need the following
New maf (again, 2nd one) N75 unsure whether to get the standard or a J version, Check my lamba connection ( may new lamba further investigation will soon work that out, also a new outside air temp sensor ,
New number plate lights fitted with white leds all in the finer details, new drivers side electric window switches fitted along with some aero wipers that i got as a xmas prezzie.
Also was bored on xmas eve so did the n249 bypass thingy
welcome to the happy world of seat.
Car going into the bodyshop for a polish so may get pics then after it gets a good clean and all shiny again
Will keep up to date on my boost issue, Oh the joys.
The MAF issue never came back after I cleared it Will. Dont think you need another one.
Took the car for a run and there was hesitation when the car as under load between 4000rpm and 5000rpm, after a quick search on here it looked like it may be spark plugs and coils,
Coils and sparkplugs taken out to find the spark plugs really sooty cleaned them up and back in they went. 2nd run of the car and the car was backfiring repeatedly at 4000rpm. I know that the car is due a service so oil and sparkplugs will be getting changed soon, and will check to see if any of the coils are weak or just knackered.
Update
Also my secondary water pump is running excessively long after the car has been switched off and need to pull out the 30 amp fuse nearest the wing on top of the battery to switch it off, could this be why that fuse melted before? New secondary water pump needed?
Wilz
Looking very nice bud, make sure you get loads and loads of a good wax on there before you start to drive it and have a good washing schedule on the go and theres no reason why she won't look this good for years to come. If you need any advise about the above give me a shout, Allen has my number.
That looks really tidy now mate just hope its kept in that
condition.![]()
Poor boys is what I have for my wheels but never used it due to them being as scabby as a ferrule cat, but that is what I would recommend.Junior the car isn't on the road till march so its hidden away in a garage all the time, All its had done so far is the three step meguiars stuff with the wax cleaner, deep crystal polish and carbanara(sp) wax. Took the rotary to the windows and lights.
Still needs a good few coats still, hopefully a coat every weekend, might just get your number from Allen if your the man with the washing and maintaining car knowlege. Still need to get some wax on my wheels any recommendations? Poor boys?
Hopefully get to some meets in March, don't think the pug would have been a good start to the meets.
Will do have always kept my cars clean apart from the winter hack pug but even then it gets cleaned at least every 2nd week, for being a winter horse it looks ok.
