Bit of advice reuvers
Buy the motorsport clamps ive got....There a must Imo as you have no swadge lines on the Pipes....
Otherwise u'l keep poping them off...
thinking of going the same routewill do mate, you want to go the same route with your piping or what?
why dont you just get a swage put on the pipes?
nice mate you gone you 63mm instead of 57mm??witch washer bottle are you gone use??so those clamps are the ones to use then on the pipes that don't have the upstanding edge...will do
tarzan, this route is also slightly bigger in dimension so should have better flow. I'll keep record of what I do.
