coming on awesome baz
Any question or owt just give us a shout....Defo get them T-bolt jubliee clips tho
Whoops!
Need to match in your engine bay tooor are not bothering about that?
Any question or owt just give us a shout....Defo get them T-bolt jubliee clips tho![]()
Do have one question bud. CR turbos the best guys for the job? and would you recommend a MBC or an electronic one?![]()
Cheers bud, you were right. Glad you convinced me to go for the bigger power. Was worth every penny to see the looks on the faces of scooby and evo drivers as you pull along side lol It'll be back
Yeah Cr turbos are the ones who built the on you've got...If funds allow get a EBC but a MBC is just as good and run a healthy 1.4bar like i did...was a true weapon then...
you got a manifold yet mate?
if you do go for a manifold, get the INA high flow one
fits well and the runners are larger than the Kinetic manifold, and its also a bloody good price, around £200 dependant on the exchange rate
Yup He's spot on for a change lol....Theres also the THS one which is very good too for slighty cheaper..
But please stay away from the ATP one....It isnt worth a penny...Its mapped to 19psi on the n75 IRRC so run a MBC like i did and tweak it to 21psi...Defo makes a whole world of difference...
shut you "oh my god my worlds falling apart, car is going......oh no now its staying, oh now im going BT blah blah blah" TART
sorry Bazzle, its a personal thing
anyway, on with your build
EDIT: What seals indeed, are you saying the seals on the turbo have gone already?![]()
EDIT:
What seals the GT2X Seals? It was built less than 1500 miles when i had it..
Righto man, got that noted and will deffo goin for some other sort of mbc, i just had the N75 which let it spike quite alot, hence why i think the seals went.
MBC or EBC are deffo the way to go. I had an MBC but no idea where i put it.
Yeah the turbos pissin out oil. Fine on idle, took of the boost pipes and rev it up a little bit and it showered my engine bay. I know it was fine when i got it though so im deffo fittin a boost controller of some sort this time round.![]()
Can u not send it to cr turbos and say its went as it hardly covered 2000 miles..i can send the recipt to you...
Probs get it done for free?
Also when u say pissing out oil is it coming from the turbo or the line (Feed) going in to the turbo unit at the top?
Don't forget its got a 1.5mm restrictor for the oil which brings the pressure down..So if it aint done up tight it will leak oil..
It done the same with me So i ditch the 90degree bit and put it straight on which then it was spot on..
wot gauge holders are you using??
where did you get the pillar one fro ifyou dont mind me asking?
