I must have had 50 MOTS and have never had my car jacked up.
Strange
50
you best read this....... Click This
save you a bit of time, specifically the steering and suspension sections
Strange
50how old are you?
save you a bit of time, specifically the steering and suspension sections![]()
just asked as IIRC , when the cars jacked up a loose spring is an MOT failure. think its so if changing a wheel at the roadside, your suspension doesn't fall apart![]()
the 90% bend I'm reffering to is located between the intercooler and the intake manifold, and is located under the headlight.
as for joining to the OEM hose joiners........you could cut the silicone hose, leaving enough hose attached to the joiner to jubilee clip onto an aluminium pipe![]()
Would love to get my FR TDI running hybrid...
Hmm maybe next year!?![]()
Has your car ever been jacked up during an MOT?
every car is for inspection.
when its on the ramp and they are inspecting the underside of the car, they jack up the front and then the back, to inspect various components.
assuming its things like arm bushes, brake discs, brake lines / hoses, CV gators, suspension springs etc etc
I'm 28, but I own/have owned/repaired a lot of cars. I believe you. I'm just saying its never happened to me. Anything they need to check under the car is always done while its on the ramps.
you should, it doesnt cost much either, only downside is your car is off road a week or so.
is there any point changing that plastic pipe for an aluminium one?
little confused about what you mean about cutting and joining the originals to silicone...![]()
from the stealers depending on which one it is!
andy, do you have a front mount with the hoses on?
how much is not that much then ?
Item 8 is the standard pipe that goes from the intercooler and under the headlight. this also has the housing for the MAP sensor in it.
in the diagram, at the end where the pipe is connected to the intercooler, it is moulded around the crash bar i think, which is unnecessary and causes a resrtiction. a straight pipe would increase air flow
have a look on the Forge website at the Seat Sport FMIC fitting kit, there is a guide to fitting with pictures which will show you a straight pipe can be fitted and what parts you'll need
re: cutting hoses....looking at part 11 which connects to the inlet manifold, at the right hand end this has a OEM 'male' coupling joiner, which connects into the 'female' joint in the manifold, if you cut the left end coupling off, you are left with the male coupling on the right that goes into the intake manifold attached to a 90% silicone hose, which you can then clamp an aluminium tube in with a jubilee clip.
point to note though, that these OEM silicone hoses with the metal coupling on, should you want to replace them and return to standard, are about £50 - £100 eachfrom the stealers depending on which one it is!
i got a Forge FMIC setup with custom pipework
When i upgraded the OEM setup for the 312mm TT setup, i asked the question about putting bigger brakes on the bake and was told there isn't much point
what size discs are used in the R32 rear setup?
cannot wait till this wee motor is finished. going to be a hybrid powered, smooth riding beast. keep up the good work ma boy. !!
gulo ;-)
Do you have any pics/info of the R32 rear set up?
Theres not a huge point to upgrading the rears from a performance point. But I always feel the rear discs on the cupra look pretty stupid as they are tiny. And one of my calipers needs a rebuild anyway so it would be a good excuse lol
