Coops's Black Leon Cupra R - UPDATE: Miltek De-Cat Fitted and sounding sweet!
Nov 7, 2009
858
3inch tip makes a big difference. Im waiting on mine from bill, then wmi. But good figures coops. Happy rollers or not. Makes no difference. Iv never been to amd essex but im sure they will have a good set of rollers.
brad1
As I said before lads I will try and get some logs done. I only have the free version, what should I log, just airflow?
You can slate the rollers all day long how many hundreds of you have used the RR at AmD?!
I have the free version aswell and you can log the air flow :) cant remember the exact block, think its 003?
brad1
Yeah I can do airflow no probs, 003 it is ;)
Just wondering if i should log anything else
Could log inlet air temps, not sure what block that is tho. Glad your happy with the map, roll on this wednesday and the 24th for me :)
RS6
Nov 24, 2009
1,110
Coops thanks to you im booked in for the same map 5th feb, getting a full service done and new spark plugs same time at AMD essex i can't wait! :D (just hope the car doesn't blow up)
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
You will love it... ;)
coops10
Newbie
Sep 1, 2009
734
Middlesex
www.coops-photo.co.uk
I looked at the graphs aswell and coops10 power doesn't drop off and holds it all the way to the red line line, tOm's car makes good power but drops off before the red line, only mod coops10 has over tOm is the 3" TIP. I honestly believe the standard TIP and forge TIP are both a restriction in any set up, the 3" TIP is the key to more and better power ;)
I have a few more mods than Tom...
Forge FMIC instead of TX Autosports FMIC
Debaffeled charge pipe instead of standard (polished) charge pipe
Cold Air feed to Jabba heat shield compared to just jabba heat shield (probably makes no difference with bonnet up anyway)
Larger Jetex cone (plastic end) instead of slightly smaller Jetex cone with chrome end
3" TIP instead of Forge TIP
Forge MAP sensor pipe (less restrictive) compared to standard MAP pipe
Forge upper boost hoses compared to standard boost hoses
h7 cya
453
Awesome results mate, you must be over the moon. Really liking the power delivery in the graph too. How does it feel on the road with the new map loaded?
brad1
As said both fmic's do the same job. Debaffled charge pipe doesnt seem to make a difference, only sound difference was noted by a couple of people. Cold air feed wont matter on the rollers, i doubt the small size difference would make much difference. Boost hoses wont make a difference, just spool up time will be quicker with uprated forge ones as they dont expand like the oem ones. MAP pipe may make a slight difference but no one has said they noticed any major difference. I truely believe your extra power over tOm has come from the badger 5 3" TIP :)
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
The TIP could be making alot more than we all expected. I've got to adjust my jetex slightly, at the moment the metal joiner goes too far into the filter, so flow isn't laminar downard into the neck of the filter as it gets sucked in. It has to go around the metal before being sucked towards the MAF/TIP.
I think we need my 3" TIP to turn up and for me to go back on the rollers with that fitted and see what happens.... :whistle:
Could go on allday debating and comparing mods lol.
coops10
Newbie
Sep 1, 2009
734
Middlesex
Feels great! Just doesnt stop pulling all the way to the redline. Lots of torque all across the band too.
Charge pipe seemed to help spool up when I fitted it.
Shaun did mention that the Forge FMIC has much better flow rates than the cheap ebay coolers. Some of them actually make things worse! But the TX one is very good and not one of the crappy ones.
Very true mate. The 3" TIP and yours rolling again should prove a few things
coops10
Newbie
Sep 1, 2009
734
Middlesex
Its annoying isnt it! Someone else gets a good gain and you cant but help spending money lol
DK and Tom persuaded me to get the work done on Sat, kinda glad they did now :D
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
And now it's the same with you making more than me and me buying into the hunger for more! :lol:
3" TIP should be here by the weekend fingers crossed..
JamJay
California Bound
Hi Coops,
Just a quick one about your R32 FARB...
Did you notice any postive effects on traction once this was fitted or purely just less body roll and tighter turn in?
I'm trying to weigh up if it's worth buying a bigger than OE LCR FARB or just replacing the OE bushed with polybushes.
coops10
Newbie
Sep 1, 2009
734
Middlesex
Hello mate, Its hard to say really as it was all fitted at the same time.... FARB, RARB, shocks, springs and poly bushes.
But the difference in the whole car was amazing. So much sharper, much less roll, less of the front of the car lifting up under acceleration, better turn in. Cant say I noticed that much difference in Traction to be honest as its always a problem :lol: but im sure it had some positive effects.
8bit
3,401
Aberdeen
Willie is the man to speak to about ARBs. He took me for a spin in his (he has R32 FARB and Neuspeed RARB) and it was crazy in the corners, totally flat, felt like a Scalextric car it stuck to its' line that well.
EDIT - should have said, I'm getting just my R32 FARB fitted when the car is in for the MOT at the end of this month so I'll be able to report back on what effects that's had in isolation.
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
I have pretty much the same as Willie... R32 front ARB, neuspeed rear ARB, front S3 brace, rear hughes engineering brace + all polybushed.
Handles like a dream ;)
Very envious... I need all of the above, but I'm just undecided on the rear brace as of yet.
