3inch tip makes a big difference. Im waiting on mine from bill, then wmi. But good figures coops. Happy rollers or not. Makes no difference. Iv never been to amd essex but im sure they will have a good set of rollers.
As I said before lads I will try and get some logs done. I only have the free version, what should I log, just airflow?
You can slate the rollers all day long how many hundreds of you have used the RR at AmD?!
I have the free version aswell and you can log the air flowcant remember the exact block, think its 003?
Yeah I can do airflow no probs, 003 it is![]()
Just wondering if i should log anything else
I looked at the graphs aswell and coops10 power doesn't drop off and holds it all the way to the red line line, tOm's car makes good power but drops off before the red line, only mod coops10 has over tOm is the 3" TIP. I honestly believe the standard TIP and forge TIP are both a restriction in any set up, the 3" TIP is the key to more and better power![]()
I have a few more mods than Tom...
Forge FMIC instead of TX Autosports FMIC
Debaffeled charge pipe instead of standard (polished) charge pipe
Cold Air feed to Jabba heat shield compared to just jabba heat shield (probably makes no difference with bonnet up anyway)
Larger Jetex cone (plastic end) instead of slightly smaller Jetex cone with chrome end
3" TIP instead of Forge TIP
Forge MAP sensor pipe (less restrictive) compared to standard MAP pipe
Forge upper boost hoses compared to standard boost hoses
As said both fmic's do the same job. Debaffled charge pipe doesnt seem to make a difference, only sound difference was noted by a couple of people. Cold air feed wont matter on the rollers, i doubt the small size difference would make much difference. Boost hoses wont make a difference, just spool up time will be quicker with uprated forge ones as they dont expand like the oem ones. MAP pipe may make a slight difference but no one has said they noticed any major difference. I truely believe your extra power over tOm has come from the badger 5 3" TIP![]()
Awesome results mate, you must be over the moon. Really liking the power delivery in the graph too. How does it feel on the road with the new map loaded?
The TIP could be making alot more than we all expected. I've got to adjust my jetex slightly, at the moment the metal joiner goes too far into the filter, so flow isn't laminar downard into the neck of the filter as it gets sucked in. It has to go around the metal before being sucked towards the MAF/TIP.
I think we need my 3" TIP to turn up and for me to go back on the rollers with that fitted and see what happens....
Could go on allday debating and comparing mods lol.
Coops thanks to you im booked in for the same map 5th feb, getting a full service done and new spark plugs same time at AMD essex i can't wait!(just hope the car doesn't blow up)
Its annoying isnt it! Someone else gets a good gain and you cant but help spending money lol
DK and Tom persuaded me to get the work done on Sat, kinda glad they did now![]()
but im sure it had some positive effects.I have pretty much the same as Willie... R32 front ARB, neuspeed rear ARB, front S3 brace, rear hughes engineering brace + all polybushed.
Handles like a dream![]()
Very envious... I need all of the above, but I'm just undecided on the rear brace as of yet.
