Got my Self a MBC So im going to try that...From speaking to Forge with my boost Pressure id want to see 8-10psi Static Pressure so il wind the actuator in a tiny bit more then Fit my MBC on its own then try it from there..
Tell you guys something took the car to 20psi ealier and the Boost Needle is Rapid At flyin round...Boost is so god dam Hard when spooling up...
And What Rpm Should see Boost by on a k04? So when im Slacking it off i dont make it too slack..
