andrewbarnard15
Does that mean the new law won't comply to a 57 plate then? So it will still pass the MOT without the DPF?
Em! Is this the way of a reputable company?
Chiptuners
Interesting!
Yep wish mine was 08 and not 58
Really? This is the first ive heard. Thank god mines a 08
They carnt gurantee a MOT pass mate!
VOSA couldnt say tommorow, Right we are going to lower the smoke limit of all 58+ Cars to 0.1 instead of 1.5, The car simply wouldnt pass!
a hole is cut in exhaust above dpf filter .filter removed exhaust welded up ,soft ware for sensors sorted out and then remap .about 2 hours work. car runs like a dream . gaurantee 4 life also m.o.t pass check out ecuflash.co.uk. my car should be about 240 bhp now with mpg gains
My car passed MOT with 0.1 any how lol with dpf removed
Do they supply a full replacement pipe that you can swap in/out with the DPF pipe or, as I probably imagine for the price, do they simply cut out the DPF and weld in a new pipe?
urs is 07 or 57 tho isnt it? yours will have been tested at 2.5 limit rather than the new 1.5 limit for 58 plated cars
Researching the website more - They actually cut a big square plate out of your exhaust system, where the DPF filter is.
Then remove the filter, then weld the plate back onto your exhaust, to seal it up again, leaving a void in your exhaust system, where the filter used to be !
- So yes, I imagine any dealer would know something had been done pretty quickly, with the obvious tell-tale welding work around the exhaust pipe (if you are concerned about warranty).
- No option for replacement pipe, or interchangable piece of exhaust / DPF filter.
Theres a handful of pictures on the website that shows this process.
Still, for the price, it gets the job done (rids you of your DPF filter), looks a pretty neat job + you get your car remapped in the process.![]()
its a 08 plate. the smoke meter reading had Limit: 1.5 on it and my reading was 0.1
Had my mrs pd170 done at Ecu-flash a week ago.
No problems to report so far.
At £400 cant complain.
Taz
