Leon Tdi FR 170 owners - Milltek DPF removal downpipe
andrewbarnard15
Does that mean the new law won't comply to a 57 plate then? So it will still pass the MOT without the DPF?
FR_Flavoured
This is interesting - but come 2012, how will EVERY MOT Tester in the country (many of which dont even specialise in SEAT / VAG cars) remember come MOT time, to check the DPF filter ? :confused:
Mines an 07, so I'll still be good to (DPF) go! :D Just waiting for things to settle, and the "DPF Delete" procedure be a task most tuners can do in their sleep - with no repercussions. :)
AndrewJB
Friend to SEAT UK & Cupra Racing
Aug 16, 2007
11,175
485
Maranello
Easy! The same way they dont forget to check Cat's on Petrols or Check wiperblades
It will be on the list of stuff to check, DPF's arent just a VAG Thing theve all got them now, PUG call them FAP's
mark131
a hole is cut in exhaust above dpf filter .filter removed exhaust welded up ,soft ware for sensors sorted out and then remap .about 2 hours work. car runs like a dream . gaurantee 4 life also m.o.t pass check out ecuflash.co.uk. my car should be about 240 bhp now with mpg gains
AndrewJB
Aug 16, 2007
11,175
485
Maranello
They carnt gurantee a MOT pass mate!
VOSA couldnt say tommorow, Right we are going to lower the smoke limit of all 58+ Cars to 0.1 instead of 1.5, The car simply wouldnt pass!
mds1256
Facelift Leon Cupra
Jan 7, 2007
1,012
My car passed MOT with 0.1 any how lol with dpf removed
FR_Flavoured
It all sounds so simple. Almost keyhole surgery! :D
Again, the only real test with such a procedure is long term, how the car behaves / also how the ECU responds with no DPF Filter!
FR_Flavoured
Do they supply a full replacement pipe that you can swap in/out with the DPF pipe or, as I probably imagine for the price, do they simply cut out the DPF and weld in a new pipe?
Researching the website more - They actually cut a big square plate out of your exhaust system, where the DPF filter is.
Then remove the filter, then weld the plate back onto your exhaust, to seal it up again, leaving a void in your exhaust system, where the filter used to be !
- So yes, I imagine any dealer would know something had been done pretty quickly, with the obvious tell-tale welding work around the exhaust pipe (if you are concerned about warranty).
- No option for replacement pipe, or interchangable piece of exhaust / DPF filter.
Theres a handful of pictures on the website that shows this process.
Still, for the price, it gets the job done (rids you of your DPF filter), looks a pretty neat job + you get your car remapped in the process. :)
ashley600
193
leicester
RR graphs needed to back up your figures
mds1256
Facelift Leon Cupra
Jan 7, 2007
1,012
urs is 07 or 57 tho isnt it? yours will have been tested at 2.5 limit rather than the new 1.5 limit for 58 plated cars
its a 08 plate. the smoke meter reading had Limit: 1.5 on it and my reading was 0.1
cogdoc
Very interesting....thanks from down under - where we don't get anywhere near the options you guys get!
kinjamin
Black Altea XL 170
May 9, 2009
159
Em! If you want to sell your car you probably need to state that the DPF has been removed. I dare say that the DPF cannot be put back?
Had mine replaced by *** in Chesterfield and kept the original part just in case I wanted to sell the car later! Its simply the matter of replacing the part and re flashing the ECU with the original software! Around 2 hours worth of work!
Also I did do a little research and there is a website chi*tuners that had flagged ecuflas* dont know why but thats what I read!
Just my two pence!
Kinjamin
