Looking good, got my lcr pump to fit in the morning as that arrived today
Should sort out your lean running i presume?
Do you not think its fuel pump related then?
Could always go hybrid?
All about cash flow though i suppose!
Ill let you know, i wont know myself if it sorts the fueling out until i get my wideband fitted.
Need to find somewhere to weld the boss onto the downpipe so i can fit the wideband sensor first
Hoping it sorts it though fingers crossed
K04 hybrid would be fun![]()
Im running sports cat not decat so i have to fit it before the cat
Also read that if its too far away from the turbo it can get inaccurate readings?
Good stuff maybe your pump was fooked
Yer does clear it up looks great long story short I disconnected the cable from the catch side and not the ball joint behind old washer bottle. Few days later could not work out how it went guessed it got it jammed I got stressed and attacked it spring whent flying cable snapped.
Funny looking back found a guy breaking a Cupra not far away so collecting on Monday
