Status
Not open for further replies.
wideband is a standard lamda boss and the egt is normally a 1/8 NPT boss.
Yeah its fine, you want the egt as close as possible to the turbine housing (you can also mount it in the manifold collector or the turbo houseing itself) and the wideband sensor about 6-10" downstream
Prototype sandwich plate made, works a treat
make sure the nozzles end face is as close to flush to the ID to ensure the spray does'nt hit the edges and blob. you will need the nozzle to know how deep to tap the 1/8" npt thread
That one was more just to test the hole spacings, can be easily remodeled. Good point though!
I will be using the AEM kit, do you have one to hand? if so could you let me know the dimms of the nozzle??
bell me late tomorrow and i will look one out - the ket bit will be the taper thread and how deep you run the tap will determin the protusion
The V6 4motion TB is 70 OD an would of plugged straight in i have one to hand.
Worked out about £240 with p&p adaptors postage & customs charges.
You wont need 550's for hybrid, lcr injectors will do you fine
Easy mod too just need to get it cut, and swap the chip over.
Dont need to worry about the remote central locking as my clifford takes car of all of that
Status
