Status
Not open for further replies.
She's a beut mate and a real labour of love!
loving the work james
Cheers Guys
what engine mounts did you go for? i need a new set mine are well on the way out!
I only replaced the front one as the rear and gearbox were fine. Its a VF engineering mount from Intergrated Engineering.
MASSIVE improvement! I used to be about to rock the engine a fair few inches back and forth but now she sits solid as a rock.
Which one did you get how hard is it
Also how hard is it to fit
First of all sorry James for clogging up your thread bud!
However I have competition level ones because I cant have any movement when I fit the big turbo as there is a lot of custom pipework like DP which can break if there is too much movement.
As for fitting the front one is really easy - one 16mm bolt on top and a hex bolt underneath - just remember to use a jack to hold the weight of the engine when you undo the bolts! The gearbox one is a bit of a pain - I found the easiest way was to undo all 3 of the gearbox to dog mount bolts as well as the large bolt on top - and completely remove the 2 which are easier to access, then just pivot the dog mount back wards on the loosened bolt and undo the 2 vertical bolts which hold the actual mount in its housing. Pop new mount in and put the central main bolt in a few threads so that it aligns, swivel the dog mount back and do everything back up.
I'd say front mount took 10-15mins and the gearbox took 30-40. I haven't done the rear engine mount because it looks like a real pain with the turbo and manifold in situ, however not impossible. I will do my rear engine when the turbo is off in September.
Hopefully this is of help to a few people hence writing it here :)
Joe
Looks awesome now mate
That tip is huge lol
What have you done with the hard metal water pipe that runs beside the tip?
Coming together :) Yeah I can see why people have such good gains from it.
As for the hard water pipe, it has been cut back and then I am going to run rubber hose up to the heater matrix (hopefully avoiding the turbo on the way)
Fitted a few more bits and bobs today, here's a pic to give a bit more of an idea what the bay will look like..
I have decided to buy a qpeng 2.5" downpipe to run the car in for a few 100 miles before it goes for a full 3" custom downpipe and custom mapping.
I am going to run it with the boost controller wound right down and leave the 225 injectors and fit my 550's when it goes for mapping.
looking good james :) almost done , my car is back at garage tommorow to replace the downpipe gasket thats been cause issues and replace the intercooler for a larger core rated to 450bhp. it seems i keep having set backs then hopefully off to bmc in two weeks to get all these bits fitted , considering getting cheap mbc i was told they do the job really well , opinions would be good
Getting there, still a fare few jobs too do though, but I can see the end now!
As for mbc I wouldnt buy anything other than a forge unos.
Bled the brakes and clutch to check for any obvious leaks from the new lines and all looks ok.
The clutch is light as a feather too which I was not expecting! Its no heavier than my old vr6 clutch
Had that exact brake set up on mine mate & i felt no brake fade with glowing disks lol
Very good set of brakes for such little money in my eyes which u will soon experience.
that is very interesting as i really dont rate my tarox 6pot setup gets hot very fast breaking is an issue with me anyhow.
Status
