Ok cool, did it work ok when you done it
Been meaning to do it I got to do the upper boost hoses so I'll give it a go at same time, might give me more room. Do you think a metre will be enough ??
I did this the other week and did notice a slight improvement on boost , it seemed to hold the boost better when putting my foot down!
Well it worked in as much as nothing bad happened but in all honesty I can't say it made any positive difference, not on my car anyway. I wonder if some folks with older cars maybe have older revisions of the N249 that have issues, maybe mine is a later one that works fine so the bypass doesn't benefit me any.
I undid the bypass recently to try and track down another issue. Undoing the bypass didn't fix the issue but I didn't notice any loss of performance, response or any real difference at all, so I've left the N249 in place for now.
I put the n249 back in place yesterday, after having the bypass for a good 6 months, same thing really my missus reported a problem which turned out to be a normal dv noise lol.
I defo noticed a difference, holding boost under full throttle and the dv sounding crisper and more positive. The car felt better without it if I'm honest. Mine is a early 53plate 225 LCR is your a late model?
Yep, registered December 2005 on a 55 plate. I might do it again sometime i've got access to someone with VAGCOM and run some logs with both setups but I don't hear mine dump even slightly when pressing on.
Great guide, it helped me a lot, thanks! :clap: I haven't tried the car yet since the mod, so I don't know what difference it'll make. :) I'm using a Forge FMDVSPLTR DV by the way.
Besides all the benefits, what are the cons of doing this mod? :confused:
If Im correct, the amount of boost will be the same, but the buildup and delivery is faster (and therefore more spikey) with the N249 bypass, than without
Hm, than I shouldn't be worried. :) Thanks!
The car feels better when accelerating and between gear changes so I really like this mod. :clap: I've only connected the original hose from the DV with the other hose I've disconected from the N249. It's really hard to find a proper 4 mm hose here as I've found out... :rolleyes: But I'm not giving up! :D
It's a miracle! :D I've found some proper 4 mm hoses for just £3,75 here. :clap: I've replaced the original, thicker hose which comes from the top of the DV to the N249, I hope it'll be okay. :) I've secured at the hose connector with two small clamps, it should be fine (although the connector has bent a little bit, I assume because of the heat :rolleyes:). :)
Nice! Just make sure you cant suck in air via those hoses, it needs to be vacuum.
The connection seems okay, I've put a clamp on both hoses which are connected by the joiner, as near as possible to the connector itself. :think: I could only use a cable tie on the top of the DV, the FMDVSPLTR doesn't have enough space to fit a clamp there. :)
