Graeme's LCR - Now Sold *wave*
8bit
3,401
Aberdeen
I spoke to him last year to help me solve some problems and possibly get a map done after that. He said he recommends a lot of folk get a 4bar FPR. I'm pretty sure Willie got one and he got a stage 2 map from Dave. I ended up going for Revo in the end so don't need it, plus I'm "only" stage 1.
I did read somewhere that Dave uses Stealth base maps and tweaks them to suit the car, it may be that Stealth stage 2 maps still have the 4bar FPR requirement (although that may not be the case at all). As Jokerman says the way to tell would be to log injector on time and calculate injector duty cycle from that. If the IDCs are getting close to 100% then it's time for a 4bar FPR. Depends on what you want from a map though - personally I tend not to redline my car, I like blasting up through the gears. Remember that you're stressing the engine, turbo and transmission most at the top end anyway, and exhaust gas temps on K04 1.8Ts get seriously high at the top end.
Jun 23, 2011
627
Inverurie
New Turbo pipe added will get pics up later
new double din sat nav headunit to go in , sent center console away to get custom made to fit it (wont get it back till mid august as the guys away on holiday)
ordered weitec 50/40mm springs/shocks kit today from dpm
ordered glovebox insert along with new LCR bushes and bearings etc for the front top struts
earlier in the week after stripping the carpets out to dry them up from a previous leak from a while back , everythings back in and smelling freshhhh so thats good , wasnt loving the stripped look tbh, so happy there back in :p lol
Jun 23, 2011
627
Inverurie
627
Inverurie
Rolling road on Sat got a nice result of 285bhp :D , ill get some pics of the printouts and post them up later , heres a Log Neil(8bit) did for me while it ws on the rollers , anyone care to have a look and tell me how it looks XD (as all i see is numbers o.0)
Code:
Saturday	15	September	2012	11:19:09
1ML 906 032 A  		1.8l R4/5VT         0002
	Group A:	'002				Group B:	'020				Group C:	 Not Running
		RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME					TIME
MARKER	STAMP	 /min	%	 ms	 g/s	STAMP	 CF	 CF	 CF	 CF	STAMP
	0	1440	78.2	6.12	21.58	0.4	0	0	0	0
	0.8	1400	84.2	6.8	24.14	1.2	0	0	0	0
	1.6	1400	77.4	6.12	20.75	2.02	0	0	0	0
	2.42	1360	75.9	6.12	21.86	2.82	0	0	0	0
	3.22	1400	85.7	6.46	23.33	3.62	0	0	0	0
	4.03	1360	83.5	6.46	22.69	4.53	0	0	0	0
	4.93	1360	72.9	5.78	16.89	5.33	0	0	0	0
	5.74	1320	77.4	6.8	21.11	6.22	0	0	0	0
	6.64	1400	85.7	6.8	24.33	7.13	0	0	0	0
	7.65	1360	86.5	6.8	21.78	8.05	0	0	0	0
	8.45	1320	88.7	7.14	22.89	8.85	0	3	0	0
	9.26	1280	87.2	7.14	20.39	9.76	0	3	0	0
	10.25	1280	88.7	7.48	22.75	10.65	0	2.3	0	0
	11.07	1280	87.2	7.48	21.28	11.57	0	2.3	0	0
	11.97	1560	88.7	7.48	27.53	12.37	0	2.3	0	0
	12.78	1960	99.2	8.5	40.92	13.18	0	0.8	0	0
	13.58	2480	118.8	10.2	63.47	13.98	0	0	0	0
	14.4	3160	175.9	17	120.67	14.89	0	0	0	0
	15.29	4160	191.7	18.7	156.83	15.71	0	0	0	0
	16.11	5080	191.7	18.7	199.44	16.59	0	0	0	0
	17	6000	185	17	213.97	17.4	0	0	0	0
	17.82	6480	23.3	1.36	0	18.3	0	0	0	0
	18.72	5160	14.3	0	12	19.21	0	0	0	0
	19.61	3840	12.8	0	8.81	20.01	0	0	0	0
	20.52	2800	15.8	1.7	8.53	21.02	0	0	0	0
	21.53	2120	17.3	1.7	7.67	22.01	0	0	0	0
	22.41	1600	15.8	2.04	6.08	22.83	0	0	0	0
	23.34	1320	15.8	2.04	5.86	23.84	0	0	0	0
	24.24	1680	15	0	4.89	24.64	0	0	0	0
8bit
3,401
Aberdeen
Sorry I didn't get the second log mate, not sure what was up with it. I didn't manage to get two proper ones using Matty's laptop and proper cable, ended up losing a chunk of data midway through the run.
That's a fairly healthy log I'd say, the columns marked CF are Correction Factor, basically one for each cylinder in the engine, the numbers are how much it's pulling ignition timing back by to compensate for predetonation. Ideally you want zero on all four but on a mapped car so long as it stays under 3 and only under load and at medium to high RPM it's not a big deal. You've got a little bit on cylinder 2 at lowish RPM which could be a sign if impending coilpack failure, tired spark plugs or incorrect plug gap - how are all those?
MAF readings look good (g/s column), your peak reading was 213.97 which is pretty good. You can roughly calculate bhp output by dividing the MAF reading by 0.8, that gives you 267.46. You have to remember though that that calculation works fairly well for un-mapped cars, remaps often gain extra power by advancing ignition timing so it's less accurate there.
I'll need to dig out the formula for calculating injector duty cycle from injector on time (column headed "ms") but from memory those look OK too.
Get your graphs scanned and uploaded, that boost curve of yours is awesome - no spike, just a nice, healthy value held constant. That makes for solid, smooth delivery, relatively low exhaust temps and relatively little stresses placed on engine internals. Most people have to put in a boost controller to get a curve that flat, Matty at Wallace said it was about the best one he'd seen on one of these cars.
Sorry I didn't see you again before you left, was good to meet you again, hopefully see you at another meet. Was disappointed I didn't get to hear that exhaust when it was on the dyno!
Jun 23, 2011
627
Inverurie
Well been a while since ive posted anything in here , 1year and 5months to be exact......
anyway not much of an update, just been running the car and enjoying ........
last couple months been pretty rough so a list of jobs that need done really........
Boost Leak (Not all the time, sets into limp mode)
Down on BHP (this could be due to all the other problems of course)
Traction Control Light stays on
Knock Sensor to get replaced and Torqued correctly
New Cupra R splitter , current one is fairly wrecked
Weld on a New Exhaust Tip , not rating the rusty cobra tip anymore
thats the main things , once the normal alloys are back on will get some new pics/vids up just to see the end product before it gets sold in a couple months then its moving on to bigger things hopefully!
8bit
3,401
Aberdeen
TCS light on and down on power, I'd say get your MAF changed. The ESP system needs input from the MAF to work so if the MAF is shot you get the ESP/TCS light on and you'll notice the drop in power.
You selling up?!
Jun 23, 2011
627
Inverurie
You selling up?!
i hate the f-ing MAF's on these things (i cant count how much ive changed!)
Do you think the MAF could also cause fault code 17535 (which is what i thought was a boost leak) which also puts the car in limp when it pops up , but if i clear it with the liquid gauge and its fine for a couple days etc
might try and "clean" the MAF again this weekend with electrical cleaner see if that helps anything
yeh next couple months (May-June) plan is to get some with more power and AWD so the options right now are...
Subaru WRX STI Hatchback
or
Evo 10 FQ-360 (Running costs is prob going to kill me on this tho)
or the wild card
MK2 Golf GTI (always wanted one, if i got this would keep the LCR while restoring it)
8bit
3,401
Aberdeen
What sort of air filter have you got? If it's old it could be letting dirt through which is killing the MAF. Alternatively it could be an oiled type filter, they're known to kill MAFs too.
It's possible that fault code could be caused by a faulty MAF, yes. Can your liquid gauge not monitor airflow? If the MAF is bad enough to cause significant power loss and ESP warning light to come on then you should see some very bad readings through that or VAGCOM/VCDS.
Nice choices there :) Course, what you really want is big power and RWD ;)
Jun 23, 2011
627
Inverurie
Jetex cone , recently cleaned it and put a light spray of the oil on , however the neck did split slightly , maybe its just fully split now and dirt/shiet is getting in and ive not noticed will maybe have a check of that
ah right... yeh it can
haha , well ive been looking into the STI more and u can control the diff so more power goes to the rear..... so basically RWD :p haha :lol:
8bit
3,401
Aberdeen
I've got a Jetex lying around, could probably do with a wash but it's not split. If you want it it's yours bud, just gathering dust here. Well, the box it's in is gathering dust... I'm not sure you need to oil Jetex ones but yeah, if you do then just a light spray.
See what sort of readings your LG shows for the MAF. I've got the Torque app on my phone and tablet, if you want I can sit with you while you do some runs in your car and keep an eye on the readings.
Have to say I do like the Scooby hatchbacks :) I knew a guy with an Evo X a few years back. He had a crap morning at work one day so went for a blast at lunchtime. Filled his car up when he left the office, cained it for about 45 mins and headed back. Had to fill up again before getting back to the office. Brutally thirsty. Insurance will be savage too. But if you really love the car...
Jun 23, 2011
627
Inverurie
this weekend had a check over the car - after cleaning the MAF and re-fitting no noticable change (however i need to clear and hidden codes etc)
having trouble atm keeping the TIP on at the bottom end.... making me annyoyed, think im going to hack at the heatshield, stressing the whole pipe making it want to pull off, and re-route some piping already there , was never happy with the DV routing, that will be this weekends job.
checked my jetex actually has no splits , must have been dreaming o.0
8bit
3,401
Aberdeen
It may be that the MAF element is just shot rather than dirty. I had the same issue with my TIP, you got the Badger5 one, v2 or v2.2 yeah? I ended up buying the v2.2 adapter and swapped that out recently, seems to have helped. It's not easy to get it fitted right tbh!
Jun 23, 2011
627
Inverurie
got the new adpater, fitted at the weekend , such an improvment , brother hacked up my heatshield so that the pipe wasnt getting pulled up and flattinting the pipe at the adapter end , sits really nice now as well managed to get the piping to the DV looking much better , will get some picks up.
still low on power however i wouldnt think enought to say its the MAF , and traction light still on , ill have some more tinkering before i end up either buying a MAF or a traction control unit thingy.
other problems is top side of the turbo , pipe keeps slipping off the charge pipe.. its tight just weird its started popping off now even tho it has been like it is for a while , anyway cant seem to hold , so either i need a longer silcone pipe , or need to see if i can steal some length from the bottom to pull it up more.
Jun 23, 2011
627
Inverurie
second hand ABS unit purchased , hopefully get it fitted this weekend along with fixing the top pipe not slipping off! ....... full lookover the car , fix any tiny things also this weekend , maybe get it polished up if i get the time..........
then its bye bye to the LCR , will be up for sale as soon as sorted :)
