Connor H
1,052
518
Essex
Repainting my wings and filled some dents
iammooks
1,827
1,228
I need to do something similar soon. Bought the UPol rattle cans and will probably touch up the bumper and repair the lacquer peel as well.
First time doing it, so that'll be a laugh.
Nizza
380
234
How did it feel with the new subframe ?
Its absolutely awesome. Transformed the car. Just put a set of direzzas on too which have helped massively
Couldn't believe the amount of turn in and grip its go, carousel was an eye opening, more turn in more power, more turn more power. Grip grip grip
Didnt get a chance for video as we got here and they were trying to shut the gates to the car park, just torqued the wheels and snuck out ha ha
Sent from my SM-G988B using Tapatalk
Reactions: Manic172
Nizza
380
234
What have I done to my car today.... destroyed the bottom end....the crank is rattling nicely...game over
Connor H
1,052
518
Essex
I have to repaint one wing, I tried to blend the new and old finishes and it’s not happening for love nor money! It’s always a PITA painting lol
Reactions: iammooks
Nathan penney
Active member
Jul 8, 2017
793
1,000
Liverpool
Finally got round to putting a couple of bits for sale on the for sale section. Lol
Parcel shelf and a set of team heko deflectors for a mk1 if anyone’s interested.
Pop over to for sale section for more info.
Maria
my mid-life crisis car
Jun 22, 2016
143
20
South-West
Got 6 new tyres, tracking checked on both (mine fine, "new" one 8 out so got to go back in 100 miles) - turned around and went back to have wheel weights replaced somewhere they wouldn't rub on caliper. Topped up the PAS fluid again, got the door card off and stared in disbelief at the bolts holding the plate on just as it was time to leave, jammed up window with brand new lolly sticks and old air freshener. Checked fuse and wires on the non-functioning horn and decided to leave for MOT man next month. Swore all the way home at the indicators that still work when they feel like it.
Still to do - adjust gearbox cables in the 1.6, sort flasher unit in the 1.6, oil filter for the TDi, and one bulb each - when the weather cools down a bit.
iammooks
1,827
1,228
Luckily the main part I need to sand back, prime and spray is inside the offside rear door, so if it doesn't match perfectly, it won't be too much of an annoyance. It looks like there's enough of a line there too that I'll be able to mask it pretty easily.
The rest is just peeling lacquer on the front and rear bumper and a few spots here and there, that I might even be able to correct with polish and the random orbital sander.
I sound much more confident than I should be though!
Connor H
1,052
518
Essex
I was more confident than I should have been now I have to redo half of it
iammooks
1,827
1,228
I'm assuming you were using rattle cans to do it? How did the finish turn out? Any runs or finishing issues? Right now I'm not that concerned with a perfect colour match (fifteen year old silver Leon? Good luck with that...) but just want it to look as clean as possible.
Connor H
1,052
518
Essex
I managed to patch and blend a spot on my front bumper so i tried to repeat that success on the wings (both had small dents)
Even though i was using mixed 2k base coat and 2k clear, i couldnt get the new and old patches to blend, they glossed up perfect but you could see the difference in lacquers/base coats. Very disappointed but now i know its better to do the whole panel lol
I think your silver will be easier to blend as its light, this plat silver is very metallic and you can see the new vs old glitter
my golden rule is lots of water and 2500 grit then compound polish with a foam pad once clear has hardened, with 2k clear it comes up wicked.
