iammooks
1,744
1,133
I was more confident than I should have been now I have to redo half of it
I'm assuming you were using rattle cans to do it? How did the finish turn out? Any runs or finishing issues? Right now I'm not that concerned with a perfect colour match (fifteen year old silver Leon? Good luck with that...) but just want it to look as clean as possible.
Connor H
1,015
498
Essex
I managed to patch and blend a spot on my front bumper so i tried to repeat that success on the wings (both had small dents)
Even though i was using mixed 2k base coat and 2k clear, i couldnt get the new and old patches to blend, they glossed up perfect but you could see the difference in lacquers/base coats. Very disappointed but now i know its better to do the whole panel lol
I think your silver will be easier to blend as its light, this plat silver is very metallic and you can see the new vs old glitter
my golden rule is lots of water and 2500 grit then compound polish with a foam pad once clear has hardened, with 2k clear it comes up wicked.
Maria
my mid-life crisis car
Jun 22, 2016
143
20
South-West
Feeling pleased with myself on the 1.6. Got into the door, got the trim panel and inner panel off nicely. Untangled the window cable birds nest and figured out where everything was supposed to go, worked out how to rethread the cables if need be and identified one broken plastic bracket and missing metal bracket. Chucked out all the bits of wood and old cardboard from the inside of the door where previous owners have looked and not fixed it. Jammed up the window in place properly with lolly sticks until we can get new cables and brackets or the whole lot and do the job properly. Put it all back together with no odd screws left over, just one missing that I found in the long grass with a magnet. Not repaired but confidence boosted, maybe even enough to tackle the water problem with the same door in the TDi.
Just one snag, couldn't work out how to get the inside lock button back in but will figure that one out when we finish the job properly. It just pinged off so I didn't get a chance to look at how it goes in, oops!
Other half kept looking over my shoulder grumbling how complicated it looked and saying "back in the day" a lot but I say it's easy and clever, no more pesky plastic sheeting that never sticks back on, no more scissor winder mechanisms, and a motor that sits on the outside of a metal plate for easy changing, I'm all for it. And I have to keep reminding him about the oil filter and the mess we used to get into changing them!
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
Well done You !! - Keep at it - The more you do the easier it gets and it builds confidence. I too am from an era of carburettors, distributors, points and drum brakes :)
Reactions: Manic172
Maria
Jun 22, 2016
143
20
South-West
Remember the
Thank you :) Remember SU carbs with the dashpot? And Marinas with seized kingpins? Happy days eh
Maria
Jun 22, 2016
143
20
South-West
Ah everything else mentioned so far except the cross-plys. I don't remember cranking handles or pop-out indicators either.
I guess you could figure out someone's age by what they remember!
Manic do you mean the Citroen suspension with those spheres?
Reactions: Manic172
Rich76
17
The Marina suspension used trunions, which were even cruder than kingpins. The worst thing about my 1800 Marina was the oil consumption - 50 miles to a pint. The last VW Group car I owned was a Mk2 Polo, the one with no brake servo; which meant basically you had no brakes unless you stood on the pedal. Isn't nostalgia wonderful.
Maria
Jun 22, 2016
143
20
South-West
Oh I thought they were kingpins, what's the difference?
Agreed on the oil. I could drive from Bristol to Hammersmith where I had to park up, leave it for the day to cool, then fill it back up again to go home. 1300 estate in that tasteful "sandglow beige" and kept popping the head gasket between 2 and 3. My first car :rolleyes:
Cuppyjoe
97
20
Reactions: Rich.T
Manic172
Dec 4, 2018
1,261
1,287
Hemel hempstead
www.seatcupra.net
Well for me I love old map stuff. In my time I have had 100a 120y salon and estates. 140j 160sss. 180b saloon and estates. 200l 240l laurels 280c saloon and estates and a few 300c. And a few toyota crowns mainly super saloons but had a custom estate too. Sadly I smashed them all to bits. Plus a few hundred other cars lol 15 years of banger racing I have wreaked a few lol
Nizza
380
234
Nice. How's the ride? I have the same kit. Need a new ARB to go really low though. Have you found the ARB is hitting the driveshaft yet?
I've just had some fabricated to get around this issue.
335mm which is standard is too long and get bottom arm foul,
280mm is short to driveshfts foul arb
300 is the perfect length. I have 2 for sale if you fancy them?
Sent from my SM-G988B using Tapatalk
Nizza
380
234
See
Reactions: Manic172
Reggie Cupra TDi
103
71
the ride is great to say they are budget coilovers, its not bouncy if you know what i mean, there is still comfort as apposed to riding on springs and feeling every bump on the road. honestly i have a set of bc racing on my tiguan and they are as smooth as... ride wise. I'm not sure if i am that low to be hitting the ARB on the drive shaft as it hasn't happened yet, done about 200 miles too. would say ive dropped it bout 35-40mm all the way around.
thanks scott,
Connor H
1,015
498
Essex
You reckon the same would apply to me? I have a TT arb and standard drop links, but I eyed them up the other day and I have a feeling the TT drop links will be too long. Havnt had a chance to measure them yet though.
