It was the alloy rubbing in reverse lol
The new one? Oops... Is it bad news?
Just the very edge of the inside left wheel was touching the coilover thread but only reversing? Weird. Probably need a proper alignment!
No fuss as i had some spare spacers to put on.
Wack a 5mm spacer on it
Only have 15mm spare haha
My car has needed an alignment for soooo long but i keep having to go back in and take things off etc lol . Im pretty certain just by eyeballing it the subframe needs adjusting, i believe on this AUQ platform i have no camber adjustment at all. But on the back of that i read. very cool breakdown on the mk4 of how being as low as i am introduces positive camber on hard cornering . Its not a track car so im probably not going to raise it up, but i will get some of these:
If you go for theses have a look a cb autos. You can go for the 30mm bushes then get the insert so they then fit your arms and you have even less Bush movement. Pop to my yard 1 evening if you want mate I have some in a set up you can have a look at
The more I look into boost gauges the more of a ball ache it seems to be on a diesel. I'm reading that the best place to plumb it in is just below the elbow boost pipe that connects to the EGR and that you have to cut a thread in the plastic. I'm not sure I trust a thread I've cut into plastic with that much pressure.
Any other TDI people running boost gauges who can advise?
On top of that, what's the best a-pillar pod.that actually fits?
Long gone mate.I’m sure thai was selling a complete pillar a while ago
Personally used the vent mount instead, i couldnt find any pillar pods except for a website that looked quite old.The more I look into boost gauges the more of a ball ache it seems to be on a diesel. I'm reading that the best place to plumb it in is just below the elbow boost pipe that connects to the EGR and that you have to cut a thread in the plastic. I'm not sure I trust a thread I've cut into plastic with that much pressure.
