Rich.T
1,609
932
Any higher and it'll touching the bonnet. Other than that you'll need to lower the catch can.
Yeh, its just shy of the top edge of the heat shield.
As for the catch can, the screws are barely long enough to go through the brackets they do. So will struggle to put spacers in(could source longer screws).
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,199
1,038
Kent
TBH I don't think moving either up or down a few mm is going to make the slightest difference.
Sl1ced
797
404
I don’t think you’re gonna stop the vapour, and the can will never I’ll to the point it’s going to be a flow into the turbo. The OE pcv system tends to have smaller amounts of water in. If you want to completely avoid it I’d vent it to atmosphere. That way you’re not throwing anything through the turbo
Rich.T
1,609
932
So, have a vent on the outlet of the catch tank, delete the puck and block the hole in the tip?
Reactions: Sl1ced
Sl1ced
797
404
The outlet that goes to the tip. Run a hose down under the car to safely vent the fumes out and block the hole in the tip. Removes the puck and the chance of anything going back into the tip at all
Thai-wronghorse
Dec 3, 2015
2,199
1,038
Kent
My latest breaker was like this, long hose straight out the back of the subframe - "elephant trunk mod"
Notice the super long hose in this pic
Reactions: Sl1ced
Manic172
Dec 4, 2018
1,270
1,297
Hemel hempstead
www.seatcupra.net
Afternoon all. Sorry about the lack of updates and stuff . But basically I not done much to show just more messing about trying to make stuff fit.
Nothing on this car fits. Every thing has to be modified to work.... its now getting frustrating... but here's a few pics. Will do a bigger up date on the readers rides section
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Just changed the radio... 3 hours later I now have a fixed passenger seat (adjuster had snapped and been bodged) and a semi working audio system - sub works but the amplified components are only omitting a low level sound
Reactions: Rich.T and Sl1ced
Rich.T
1,609
932
Any downsides to this?
As in lack of vacuum from the tip meaning less moisture being drawn out of the crank case etc?
Nathan penney
Active member
Jul 8, 2017
688
792
Liverpool
All this technical chat is way over my head. I like reading what everyone is up to though.
All I’ve done is wash mine today.
Had to be pressed into daily service again this week as my daily Motor has gone off to the garage.
So thanks to the bizarre freezing weather earlier this week the Leon was covered in salt again.
Sl1ced
797
404
If you plug the hole it won’t suck with the tip vac but The crank case pressure is all positive so shouldn’t cause any issues. A lot of people run it vent to atmos. I think I will go that way too
