Cheers mate. I'm afraid I'm oop north in Manchester though.Good stuff with the handling arb’s. They do make a big difference.
Now you’ll have to lift off mid corner to have it step out
People always impressed when on track how stable the back end of my car is.
K brace is your next step.
For an extra 40 quid add Whiteline Racing front control arm bushes with added castor.
Turn in changes with less front end oversteer.
Car feels much more planted.
A great mod that makes a difference that’s cheap as chips.
I have a set of H&R springs if you’re interested. Not worth paying for postage tbh but
If you’re down south you could grab them and just give us a drink.
As for the Badger5 tip.
Is your car mapped?
If not it’s probably not giving a real gain. Maybe the mind playing tricks.
I think my car maybe lost a few brake prior to mapping with all the mods attached.
Maybe you’re lucky.
Certainly, if it’s fitted with an open cone and a heat shield you will see gains of upto 8 poss 10 brake in the end. But usually after a map. Maybe half that or less while standard.
Heat shield is so important too with open cone. otherwise you can be looking at deduction in power once again.
If sticking with the air box, try a Green Panel filter.
These are pretty efficient and give the best air flow for the standard box.
Badger5 Custom Map + TIP,
I'm not remapped, but should still gain a couple of hp from higher throughflow. Possible there was a split in the old pipe though. I'll probably get the ProRam and heatshield at some point.
