B3NNYs Flash Red K03 Hybrid Ibiza Cupra - First Hybrid logs (WMI Installed)
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Cheers Damo - i was very imprssed with the condition they turned up in, absolutely no need for a refurb what so ever!
Dont worry Dan, ive already saved the old box for when i have to pack the wilwoods, plus your money will be paying for the engine mounts ;)
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
There not cheap! But who wants cheap on brakes likes these :D
They guy gave me a set of mintex pads with the calipers so im going to use these as they where in essence free but once these are gone they will be replaced with ds2500`s.
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Yep, yo gota pay through the noes when you have good brakes. My price was for ds 2500's too. Then £100+ for some good discs...
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
yeh easy, mine, grooved brembo disks where £85 +vat each!
Wasnt going to skimp this time round, plus should look awsome behind the wheel with the added bonus it should stop pretty well too. lol.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Cheers Phil.
The codes ive been getting lead my and the garage to belive that the TB had given up the goose, i bought a second hand TB and that didnt seem to cure it either so either that TB was goosed or its somthing else, i think the garage are going to try a brand new TB on Tuesday.
Sombody did mention that there is an angle sensor on the pedelitself which could be worth looking at?
Also been getting throttle valve controller - electrical mulfunction.
:confused:
wild willy
2,323
Wales
check your connections on your harness plug, make sure none of the connections are bent or cables pulled out.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
I should hear back from the garage tommrow, if they havent managed to fix it ill mention to them about checking those connection although i`d like to think the garage would use there savy and this would be one of the first things to check after the TB.
Cheers.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Well im hoping that its the second suggestion, should hear from the garage today.
If there no further forward i think im going to remove the ECU myself and bring it home and dry it out and give it a clean and go from there.
