Just to update this, I couldn't find anyone that could skim 370mm discs on the car. And when the car went into SEAT for a service, the tech agreed that the pad locating pins were marking the discs. He contacted SEAT technical for advice, and was told this is normal. Sounds like BS to avoid having to replace the pads and discs under the warranty.
No problems at the moment, but the car has done 20k road miles now, and I'm looking to the future. A light skim on the discs could have extended their life, while staying within the wear limit. I wouldn't baulk at spending £4-500 on decent discs and pads, but I think the original SEAT parts cost a lot more?See my previous comment on these pins:
Brake pads options for 370mm Brembo 4 pots
I wouldn’t the Zimmerman are ‘better’. They are a better value, half the price of OEM, weigh virtually the same, and have an anti rust coating on parts OEM doesn’t have.www.seatcupra.net
Are you actually having brake problems? How much wear do you have on your pads/discs?
The sub8 brembo brake option is an awesome brake - which wouldn't look out of place on a supercar from 10 years ago - but unfortunately that doesn't come cheap!
Its common for modern cars to need new pads and discs at the same time - gone are the days of getting 2 and 3 pad sets to 1 disc!
I wouldn't worry about skimming - just use the discs until their wear limit is reached.No problems at the moment, but the car has done 20k road miles now, and I'm looking to the future. A light skim on the discs could have extended their life, while staying within the wear limit. I wouldn't baulk at spending £4-500 on decent discs and pads, but I think the original SEAT parts cost a lot more?
Those on ebay for £389 look terrible.I think the discs are early TT-RS parts, I've seen what look to be the same discs for around £400.
No, any holes are drilled.I believe the holes are punched in the better quality discs. Drilling probably causes a stress raiser, leading to cracking around the holes.
I googled this, and Brembo appear to disagree with you...The thing is that is so ingrained that drilled discs are better that people expect it regardless of the effectiveness.
This is why people think they look better.
