*BREAKING* James Judd's Forged 1.9 Mk3 Ibiza HTA GT2868R Build *BREAKING*
Status
Not open for further replies.
Jul 4, 2010
2,170
Cambs
Heres a few of my crazy boost logs guys.. It is confusing the hell out of me.
1.54bar @6300rpm which is also what the boost gauge reads.
It has a brand new bosch map sensor so that should be reading correctly.
My guage has been tested to 30psi and is accurate.
Why does it hold so much boost????
Jul 4, 2010
2,170
Cambs
These little babys arrived today.. the 1st additions to my hybrid bits :) Next up 4bar fuelpump and maybe a k03 manifold to send to bill to port..
Apr 15, 2009
2,189
Midlands
Good stuff
Hybrid will be coming my way eventually later this year
Is the standard manifold, ported, enough for a hybrid?
No need for any aftermarket manifolds?
cuprawill
Turbo lag is foreplay
Nov 20, 2009
703
Good stuff
have a look in bills section i believe the ported manifolds flow the same if not better than high flow aftermarket manifolds.
Jul 4, 2010
2,170
Cambs
Good stuff
No a ported one flows fine on hybrid, especially if you get Bill to port it :)
Jul 4, 2010
2,170
Cambs
fits well there
will the oem pump fit in it ok
Yep thats the oe pump in mine, just lengthen the pipe to fit, take out a bit of polystyrine near the wing, drill a few holes to mount the bracket and give it a good push in.
Just common sense really only took 20 mins ish
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
are taken care of allready mate my hole bay is stem cleaned,looks very nearly new
james when you cleand out your intercooler and pipe work what sort of fluid did you use? because this is also something id like to do
Jul 4, 2010
2,170
Cambs
Nice! cant beat a clean bay.
Started off using engine degreaser didnt quite cut it so I done it all again with thinners. The degreaser worked really well on the Inlet manifold though, iv also heard shampoo works well!
Status
