May 17, 2019
I have MK1 Cupra R Brembo calipers. On one the metal pipe is corroded. I need to get a new one of these pipes or get a custom braided hose that would replace the metal pipe. I was looking at getting custom brake lines made but don't know what fittings I need on each side of the braided hoses.
cDQRtr8
May 17, 2019
None of here solve my problem, the metal pipe that connects the hose to the caliper is corroded. I either need a new one of those pipes or I need a hose that replaces/bypasses pipe (goes from car straight into the caliper). I could get a custom hose made but don't know the fittings I'll need.
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
I think I know what you mean now, the hard line that runs from the junction block in the wheel arch to the abs pump ?
So you have the rubber hose from caliper to junction block , then the hard line from the junction block that then run to the abs pump
If thats the case a replacement would be available from any Seats dealer (have a look on here) or failing that I am pretty sure you can get repair kits where you cut of the damaged bit and fit a joiner and new piece of pipe.
