just noticed your reply thanks for that
would be good to see a picture at 25%
I'll try and remember to get one for you tomorrow bud
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Mine is both interference fit and a bolt just for belts and braces.
Interference fit means press fit, where the pin is slightley bigger than the hole its going into.
You could weld it but you cant put a nyloc on due to the design of the cable ends.
Sweet that should finish the car off spot on!
Let me know if it makes any difference to the handling.
My rear hubs are starting to get a bit rusty too! Something I'll do one dry day.
Where did you get the idea to do this then?
