Mine is both interference fit and a bolt just for belts and braces.
whats that mean thats gone over my head a bit? lol
im thinking either weld the pin in or getting a different pin like the ones you get on a boot strut etc so that way i could put a nyloc nut on the otherside if i can find the right size pin.
might not work but if it does it saves me getting someone to put a thread on both the pin and the shifter.
or i can just get someone to put thread on the shifter and use the existing thread on the new pin if i can get one.
Interference fit means press fit, where the pin is slightley bigger than the hole its going into.
You could weld it but you cant put a nyloc on due to the design of the cable ends.
oh i see i miss having the use of a workshop with things like a press.
i mean put a nyloc on the opposite end of the ball which attaches to the cable or is that just immossible to do?
i dont want it to be a bodge i want it to be as close to perfect like yours but dont have the access to the sort of tools you do although im sure i know some one who can do the threads for me.
am i wrong to think maybe a tap and die kit would work?
Got myself some second hand 20mm spacers.
They were in need of a good clean though :(.
So after a good clean and some Galve spray they look like this now :D
Galve spray
Finished results
Will be fitting them at the weekend.
I could do with some of that spray for mine! Or just etch prime them, then paint them....
My rear hubs are starting to get a bit rusty too! Something I'll do one dry day.
Current state of play
This is how the car is currently sitting
Exterior:
Debadged grill with red outline
Gloss black mirror covers
Citroen stubby aerial
Polo rear aero wiper
Standard Cupra wheels in anthrecite
Interior:
Standard Cupra interior
Center sunvizor
Center arm rest
Sony head unit
Boost gauge in custome Din plate
ScanGaugeII
VW grab handle Sunglasses holder sprayed black
Carbon sill covers
Suspension & handling:
V-Maxx coilovers
V-Maxx shorter drop links
Whiteline rear ARB
Seat Sport strut brace
Ebach 20 hubcentric spacers
Braking:
Standard Seat Sport AP racing 4 pot calipers
Ferodo DS 2500 front pads
Standard rear pads
312mm Front Drilled and grooved discs
232mm Rear Drilled and grooved discs
Engine & Transmission:
Forge TIP
Forge 007p DV
Open cone filter
N249 removed and resistored
N112 removed and resistored
SAI removed and resistored
Denso Iridium IK22 plugs
P-Torque custome stage 2 map
Custome short shifter
This was it the day I got it
Ant this is how it stands today
