Mine is both interference fit and a bolt just for belts and braces.
whats that mean thats gone over my head a bit? lol
im thinking either weld the pin in or getting a different pin like the ones you get on a boot strut etc so that way i could put a nyloc nut on the otherside if i can find the right size pin.
might not work but if it does it saves me getting someone to put a thread on both the pin and the shifter.
or i can just get someone to put thread on the shifter and use the existing thread on the new pin if i can get one.
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Interference fit means press fit, where the pin is slightley bigger than the hole its going into.
You could weld it but you cant put a nyloc on due to the design of the cable ends.
oh i see i miss having the use of a workshop with things like a press.
i mean put a nyloc on the opposite end of the ball which attaches to the cable or is that just immossible to do?
i dont want it to be a bodge i want it to be as close to perfect like yours but dont have the access to the sort of tools you do although im sure i know some one who can do the threads for me.
am i wrong to think maybe a tap and die kit would work?
Damoegan
Oct 15, 2007
8,993
Newcastle
Got myself some second hand 20mm spacers.
They were in need of a good clean though :(.
So after a good clean and some Galve spray they look like this now :D
Galve spray
Finished results
Will be fitting them at the weekend.
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
I could do with some of that spray for mine! Or just etch prime them, then paint them....
My rear hubs are starting to get a bit rusty too! Something I'll do one dry day.
Damoegan
Oct 15, 2007
8,993
Newcastle
Current state of play
This is how the car is currently sitting
Exterior:
Debadged grill with red outline
Gloss black mirror covers
Citroen stubby aerial
Polo rear aero wiper
Standard Cupra wheels in anthrecite
Interior:
Standard Cupra interior
Center sunvizor
Center arm rest
Sony head unit
Boost gauge in custome Din plate
ScanGaugeII
VW grab handle Sunglasses holder sprayed black
Carbon sill covers
Suspension & handling:
V-Maxx coilovers
V-Maxx shorter drop links
Whiteline rear ARB
Seat Sport strut brace
Ebach 20 hubcentric spacers
Braking:
Standard Seat Sport AP racing 4 pot calipers
Ferodo DS 2500 front pads
Standard rear pads
312mm Front Drilled and grooved discs
232mm Rear Drilled and grooved discs
Engine & Transmission:
Forge TIP
Forge 007p DV
Open cone filter
N249 removed and resistored
N112 removed and resistored
SAI removed and resistored
Denso Iridium IK22 plugs
P-Torque custome stage 2 map
Custome short shifter
This was it the day I got it
Ant this is how it stands today
