the age of your car ? Which model ?pleaseI was told, due to the age of my car, a Rev B unit would not be compatible with my car or keys. The Rev B uses a different Immobiliser system compared to the Rev A. However no difference in functionality.
Generally speaking:the age of your car ? Which model ?please
Sadly it needs to be done by a professional with ODIS as requires all kinds of setup and your keys coding to it.Got a 2018 Cupra 300 without VC. What tools do i need to retrofit?
Contact Kieran @ https://eastyorkshireretrofits.co.u...rtual-cockpit-retrofit?variant=34924292079781Evening guys, you'll have to excuse my very foundation knowledge of retrofitting as I'm very new to this. I'm looking to get my Seat Leon FR Tech 1.4L 150ps 17 plate retrofitted with a virtual cockpit (VC).
I don't know whether my car has MIB2? I'm not entirely sure what MIB2 is or how to tell what I've got... Is it at all possible to get my car retrofitted with 5F0920790B/A as I don't see the point in upgrading my standard cockpit to 5F0920790 when it basically just digitises it. I'd quite like the central rev counter and maps to be visible if I were to spend the money and get it retrofitted.
I don't have a 'view' button on my steering wheel either and from what I can tell that seems relatively important... any advice is appreciated
17 Plate will be MIB2, however not sure if its new enough to support the optic fibre cable that goes to the VC for the map view. If it doesn;t have that you have the choice of either:Evening guys, you'll have to excuse my very foundation knowledge of retrofitting as I'm very new to this. I'm looking to get my Seat Leon FR Tech 1.4L 150ps 17 plate retrofitted with a virtual cockpit (VC).
Does anybody know the what the part number is for the multifunction buttons with the 'View' button for a DSG car with paddle shift? Struggling to find the part number. Cheers
Sadly its not just a straight swap to check, as it needs coding to the car etc. I'm not even sure you can just put the old one back in after either.Sorry, I'm back again. Basically, I'm planning on getting Virtual Cockpit installed in my SEAT. I'm getting hold of the parts for it. I've got a used virtual cockpit now. How can I view the mileage on it? Can I remove the trim on my car, take the clocks out and plug in the virtual cockpit to view the miles, then plug my old clocks back in while I get the other parts? Would this cause problems with my existing clocks with component protection or anything like that? Cheers
Who you getting to fit the new unit?
If you disconnect your cluster from the car, the long coding of abs/brakes module is set to all 0’s.
Also some basic settings will have to be redone.
Thanks for the quick reply. Sadly, I was fearing that was the case. I think its around 21.5k miles but who knows if that is true or not. I've looked into a couple of people but I've not gone any further than that at this stage. I'm about to obtain the cockpit trim, multi-function buttons and really need to change my MIB to the one with a MOST port. Do you know anyone in the Northamptonshire area for fitting? Also, do you know what the difference between 5F0919719DYMS and 5F0919719DCZH are? It says one is silver, and one is black, but I'm unsure if it's talking the colour of the buttons, or the trim colour of the outside of the unit. Cheers for your help.
FYI:
mib1/2 no Most (VC can be retrofitted):
No nav maps on VC, only directions as on FIS.
No album art, radio station logos, no telephone contact images
mib2 std with most: you have to choose between maps on VC or infotainment screen...can’t have both.
mib2 high: maps can be displayed on VC and infotainment simultaneousl.
