Awesome man :)
Where did u get the 4 bar fpr from? Cab u get them from seat?
I got the 4bar off a member on here
You will be able to get them from seat/vw im sure
Looking good, I found the most fidly part of the install was to ge the TIP into place but take your time and youll get it in the end:)
Also remember to put oil into the turbo before fitting the oil feed and return lines. Crank the engine without coilpacks before startup.
Did you use the part numbers for washers and nuts from this site
good luck
Yer ive fitted 2 tips now and they are a nightmare lol
Will the tip sit differently or is it harder to do with the k03s turbo?
How much oil do i need to put into the turbo before i connect everything?
Didnt realise i had to do that, thought the lines would do the job once it was fitted
You don't need to physically put oil in. Just make sure you turn it over a few times with the injectors and sparkplugs disconnected to allow the oil to run through the turbo via. the lines.
Thats cool, ill do that ;)
More delays
Recieved new caliper but its ythe wrong side [:@]
Now awaiting the right one which has delayed the install once again!!
Can you not just switch over the nipples to the correct side?
Ive held it up to the correct (knackered one) and it would make it upside down, brake line etc would all be in the wrong place
New ones coming monday so its only a day or 2 delay
Just so eager to get it done now soi can get it mapped etc, had all the parts 3 weeks now lol
Can you not do the turbo in the mean time?
That was the plan but the car didnt have the emmisions test and it will be done on the retest
So i was worried if i fitted all the parts then had an emmisions test un-mapped maybe it will fail?
Small update
Car has mot retest on Monday, so all going well the install should start tuesday morning!!
And
I just got payed :) lol
Still to do
Intercooler pipework
Small washer bottle
Catch tank
Rear strut brace
Lower strut brace
Bigger brakes
And most of all the Jabbasport stage 2 map!!
My new wheels will be coming soon too ;)
Hopefully lol!!
Cant wait to get it all done now suspense is killing me lol
Had the majority of the parts sat around for 4 weeks now!
Few more parts came recently
Ive decided to re-do my coldside relocation, ive not been happy with the way the hoses clamped down on the alloy t-piece so ive gone for a silicone t-piece this time, also gets rid of the blue hoses i had in the bay to.
Before
To now
I have trimmed the bends slightly to fit though as they were a bit too long lol
This goes from the throttle body to the map sensor tube, once ive bought my new intercooler kit ill be buying a forge map sensor tube
so there will be no more OE restrictive pipes and ill have a nice free flowing setup!
Replaced the red pipe from the tip to the air filter with a polished alloy pipe to break up the red a little bit
Decided as i only have one fog light due to the intercooler pipes i would run a cold air feed from the fog light to the filter so i also fitted that too :)
Thats about it for now just waiting to buy the intercooler kit then i can ditch the OE charge pipe and run the intercooler pipes on the other side of the engine bay.
Also pics of it all fitted tomorrow ;)
Recieved my new caliper today so i will be getting the car mot'd this week!
The turbo install will be started this weekend 100%!!
All good news now
Car has finally got an mot!!!
Its booked in at Jabbasport for the mapping on 20th
Fitting starts tomorrow morning :)
Cant wait!
