My On going problem (Boost/N75)
Mar 16, 2007
620
SouthWales
Yer if you cant try some1 eleses like me or do a bypass then go to the dealers because the N249 valve is £60+VAT from SEAT for the LCR ;) Hoping to solve my problem tomorro :)
Mar 16, 2007
620
SouthWales
Im going to do a bypass tomorro now if i can get the parts easy enough , i cant find any threads on here? on how to do it? is it litrally put a Tpeice in where the N249 valve is needed? where does the "resistor" go?
seatcupramad23
kc4even23
Sep 7, 2009
3,239
birmingham
thats what i'm finding also , looking if there is any step by step guides ppictures alone arent enough for me i'm very slow lol
Mar 16, 2007
620
SouthWales
Right Update today lol good and Bad :(
Fitted My New TIP and noticed my old one was the tighest on also found a large split in the hose from the charge pipe to the N75 valve so replaced that also the one good thing is that the fluttering has stopped , but my next problem now is that i have no power? it basically feels like ive lost my stage1? i swapped my N75 and N249 valves and there was no differnce so i can hold them outter the problem , i litrally checked every pipe i could for splits etc but the one thing ive noticed that my DV isnt dumping no where near as much as it should or even at all ? i swapped springs around and its not that i even swapped mine for my mates and it was exactly the same ? any ideas?
Just to add its no juddering or anything like that no misfiring etc , it just feels allot slower than it was yesterday?
Pyro
Check that the tip is still on the turbo there a tight fit make sure it didn't pop out etc and take the battery off for half hour so ecu can reset
Pyro
Yup I know your pain. :( you sure tips ok have you checked it since you've driven the car also now you've taken things apart there's a chance that you have a loose clip or a pipe slipped off etc just push everything on tight and it's all done up :D I've had to check all mine twice in one day and found loose bits or things that pop off
Mar 16, 2007
620
SouthWales
Yep TIPs not going anywhere , im thinking the fluttering was to do with the little pipe from the charge pipe to the N75 and also the orginal TIP didnt look on propaly when we changed it , but everythings on bang on now and its the same? the dump valve isnt dumping at all? ive checked all the dv pipes , and its not sticking either! Its being vagcom'd monday :(
Mar 16, 2007
620
SouthWales
Isnt it just? its frying my brain i dont think its possible but its like if the map has gone 100% so strange! But its gotta be DV related because its not dumping?
Mar 16, 2007
620
SouthWales
Yep the orginal bosch and my mated 007p :( its gotta be another leak from somewhere but its strange how the fluttering has gone and now this? Well yer im guessing its on fine? i dont know what psi its running atm boost guage was only bought last night off here!
Mar 16, 2007
620
SouthWales
Hmmm having a read through threads on this forum and golf forums and i recon its going to be the maf? but i thort when the maf go's its like coilpack symptons? and i have symptons just loss of power. Also people have been known to loss thier maps!
Pyro
Unplug it fo for a drive and the will irradiate that ;) lol What map is it?
