Dude_200
Hi, can any1 plz help me! i need to no how to remove the bonnet lever on the drivers side because i need to remove the panel bhind it. does any1 no how to remove it???? im scared ill snap it
any help wid me reli useful
no interior bonnet release. as its part of the trim pannel by your right foot
when im getting them off at work i just use a trim tool and lever it off from the base then just clicks back on :D
hmm do you open the bonnet or unhook any cables to 'give it some slack' or just go ahead and prise it of?
have tried a bit of prising from the bottom/front of the panel, i have heard at least 1 mounting pop off but it's still there quite firmly
It does NOT just pop off. If you try that you'll break it.
There's a fastening at the back that needs to slide out first. (It's in the bit you really can't see).
Standby for a picture...
Pull the actioning lever -1-, displacing some 2 cm
Introduce a small screwdriver between the actioning lever -1- and the clip -2-
Remove clip -2- from lever -1- using a screwdriver
Remove the lining -3-, separating it from the central location, at a straight angle, and from the heel moulding, by the lower part.
In the case that there is one, uncouple the volumetric alarm switch connector.
http://bayimg.com/nagemaAbF
great then the trim under the door just pops off cos i've done this on the other side already....
i think someone said removing the rear panel trim (underneath both windows) is just a case of pulling them off with a bit of controlled force....is this confirm-able ?
ive probably done 3-4 of these and ive always got themoff by prising it off with out damaging it and just clicked them back on :shrug: are you sure they are all done like this?
just done both rear panels and got the cable routed back there! altho havent replaced all the poppers because i might upgrade the rear speakers at some point
the driver side footwell lever panel is the only bit i havent got off yet :p
there doesnt seem to be any clips around the base of the lever in that panel
there is what looks like the edge of a bit of plastic molding coming, but just seems to be a molding, not a clip that moves - i tried bending it with a knife :D and it didnt slide out or anything
a knife :lol: try an axe :) flat head screwdriver would be better from the pics the clip showed is the same most manufactures use to hold window winders on!
