Thanks @SuperV8 for that.
Ok so mine's a 150hp. Anyway, just had first proper 100m drive today.. & fits me like a glove: I honestly think 184 hp might be unwarranted for the b-roads & 55mph max Aroads around me here, which is 95% of my driving.
If the engine is surely the same between the 150 & 184hp 2.0 tdi's.. how is the extra 34hp made? Some sort of tweaking the engine- mapping or something?
Reactions: SuperV8
Few more Q's of I may.
I'm having kittens about putting petrol in my mk3 Leon tdi. Having never owned a diesel before.
I've put diesel in once so far, & noticed a satisfyingly snug fit putting the fuel nozzle in. Is there any system in place that prevents the smaller diameter petrol nozzles from being inserted though-?
I think petrol cars thesedays, generally also have a very snug fit of the petrol pump nozzle.. physically preventing the larger diameter diesel ones from being inserted, although not my golf4 that just died: big 2" fuel hole anything could go into.
Thanks Z
There are mechanical differences, mainly the turbo is bigger on the 184.
In the real world you'll probably only notice at higher speeds, though I haven't driven the 150.
Well no idiocy so far, twice put diesel in without being a numpty & reaching for the green nozzle..
Chaps, could I ask: is there any way to tap into data on the fuel level, more accurately than visually in the dash?
The digital fuel level incrimental indicator.. isn't a patch on a simple analogue fuel level dial I'm so used to in my golf4. So I get a bit jittery when I suddenly see it's gone down one 'bar'. And have no idea if on a single bar (should I get that low) & it suddenly goes to none.. if that means the car has run out. Or if there's still a bit in reserve at this point.
Thanks, Zoot
Another question too!
I have alot of situations of 2 cars squeezing by each other on single lanes out here. Can I manually open window & tuck my wing mirror in? Or can this be done electrically?
If you have electric folding mirrors you can fold them in using the position on the adjuster knob.
Thanks, Zoot
When it goes down from 2 bars to 1 bar the reserve warning comes on, I believe about 6 liters left in tank.
