New maf it is then! fit it then clear the code right? how about gettin the traction control light out as the diagnostic machine wont do that! disconnect the battery?
Also it still seems to be running ok thou!
I'm in suffolk if you need it reset although I'm sure theres someone closer as I'm not that close to Ipswich.
The EM code you have is to tell you there is a code logged in the TC system, you wont be able to reset that code before you reset the TC code.
