Pictures? We need pictures!!!Painted the inlet manifold, reworked my catch can location and washed the engine bay - now it just looks **** instead of **** n mud !!
Thanks. I did myself over the weekend. Wrapped my brothers car also actually.It looks brilliant mate. Who done the wrap. I had a go at a roof and all I can say is I went for the wrinkly effect lol. It's a lot harder then it looks. And also you need the good stuff to start with
But your right, you got to start with the right stuff to begin with. and since its my job its cheaper for me to wrap the whole car as painting just some sideskirts and doorguards. So that and mismatching color bumpers made me decide to wrap it. Ibhope to finish wrapping the sideskirts tonight so i can finally fit them. Think its actually the last cupra r part i need.
The 'Battery' light doesn't actually relate to the battery at all, it's purely to show that the charging system isn't charging the battery.
As 'Chaki' said above, check the alternator belt is ok, and then check with the multimeter that you have over 14 volts at the battery terminals when the engine is running.
Haven't done a road test yet, but will probably pop out in a little while and go round the block.
If the discs have no grooves and no wobble then you you should be good with new pads, just bed them in nicely
Are you getting any screeching at all? If so get the belt replaced, there about a tenna n 10 min to change. Just take note how the belt sits on the pulleys before swapping. Make sure u get the double sided belt. Uv got the lcr right?Drove from Brighton to my parents' place in Dorset a couple of days ago, and no issues on the drive. I've just popped out to check the alternator belt and everything's running smoothly. More recently I've either been making short trips or leaving the car for long periods, so it could have been something to do with that. I'll try to get hold of a multimeter - I thought my dad would have one, but no luck so far.
Thanks for the help!
Anybody know of a decent plug to delete the aerial? Never listen to the radio and wen datas down its best of chuck berry on cd player. After market onw as the 6cd changer doesnt work. Delete beat...
Need a glove box insert.
yeah same here. or a smaller one even. https://www.banggood.com/nl/Wholesa...OzuReFFKXCAXgGYaAhS7EALw_wcB&cur_warehouse=CNAnybody know of a decent plug to delete the aerial? Never listen to the radio and wen datas down its best of chuck berry on cd player. After market onw as the 6cd changer doesnt work. Delete beat...
Do you have the helper springs on the rear calipers?? For £6 it’s well worth the addition and helps return the handbrake arm (have a look on google)
Only done 2 belts so far. Mine and one on a longitudinal q5 2.0 tdi. Forearms looked like id been juggling knives after lolIt's the FR TDI, but if it needs it, it's not a big job and I've done it before. In my mind I did it a couple of years ago, but it was probably more like ten years ago, knowing me...
