wasn't sure on year/model so checked Leon 1P 06/08/09 and all came back same number
4L0 907 391 Control Unit for discharge bulb
If it helps the same unit is fitted to a few other Seat/Vw/audi
04-09 Altea
09 Ibiza
05-09 Toledo
06-09 Eos
08-09 Passat
08-09 Phaeton
09 Scirroco
07-09 Q7
not listed Skoda/Porsche
7.0 updated to 622 it says
Yeeeah, this worked622 is a VW update.
You need to go into C:\ETKA\prog\
edit these files:
ETKA_SE.INI
ETKA_SK.INI
ETKA_AU.INI
ETKA_VW.INI
and under the header [KONZERN] change the firmen variable to the below:
firmen=VW,AU,SK,SE
Save them all and start ETKA, if you've got the updates in the folder it should then update them all. However you will have a few issues, click the SEAT logo and select maintenance, then INI- Editor, (just ok through any errors) then under the communication header click other communications and untick the checkbox and click store.
Should get rid of most of the problems![]()
Hi, you've got more info what do you alle need for oem xenon?
i've got now aftermarked xenon but i want oem xenon
what do i need to order?
the xenon headlights.
balastters
something else ?
thanks
i have just fitted these also... no headlamp washers or auto levelling tho...
saying that...i have no manual levelling either now :Lol:
Ok thx for the info!
ill go to the dealer and ask about prices
but i already know that the headlights are +- 430 € a pice
don't know if the ballasters are inculded because an other price by another dealer was
338 € a pice
greets
