Yeah it could of been Metal fragments in the oil...Get urs self a ECS magnetic sump plug
Send it to them and see what they say,,
I would'nt use the ECS thing personally... its soft ally into soft ally sump = dodgy threads
how is the drain pipe? kinked? collapsed? that will cause the same oil pissing out of seals scenario
just had a thought
Would it be the seals if it isnt blowing smoke through the exhaust even when warm..
Looks okay but you would not know if it was ever blocked before the damage started to happen unless you checked it every day or fitted an oil pressure gauge between this and the turbo.
Yeah i know but its hard to fight when its changed hands. And have you read their warrenty rules??? need proof of regular maintanance, that its been fitted by a compitant person ect. Basically they've covered every corner for if they have made a mistake![]()
C R Turbo Engineering offers a warranty, to the original purchaser, for the repair or replacement of their turbocharger for a period of 12 months from the date of purchase. Proof and date of the original purchase will be required before
Proof may be required of proper maintenance of manufactures routine service levels and intervals, with particular regard to oil and filter changers.
Failure to comply with manufactures service requirements will invalidate this warranty.It is vital that the turbocharger is fitted correctly, please follow all vehicle manufactures instruction as well as the C R Turbo Engineering checklist.
C R Turbo Engineering recommends that their turbochargers be fitted by someone possessing the knowledge to do so correctly. Incorrect fitting, poor engine condition or maintenance, insufficient air or oil filtration could all lead to warranty claim being rejected.
In order to assist and prevent further problems C R Turbo Engineering will issue a report on the condition of any turbocharger returned during the warranty period. This is usually a very good indicator as to the reason for any turbocharger premature failure.
Blah blah bah, inshort.......if it f*cks up...Bad luck. lol
surely with the Recipts ive got for you...Is way more than proof..considering its something like 3month old...
