That will be nice if the Evo calipers do fit Becks
Nice day for re sealing your doors. I have damp in the drivers side back on mine,so i need to re seal mine now better weather's coming
Car looks quality, my dad had that problem with his toledo, get in the back and its just pure water, not too bad too fix tho,
Keep the piccies coming!!
i am loving the look of this car blue and white works very well
also i am loving the shoes aswell ( bet your getting fed up of the shoe comments lol )
Re: Becks Blue Leon Cupra - Going for stage 2 and a blue and white theme
So how long do we have to wait for some decent piccies of the engine bay :p Also love the progress of the motor.
I have an imperial blue LC and your car is inspiration to keeping the car for a few years.
Thanks ;)
Well I don't like the engine cover so I was thinking sometime around never? :D
I know I need to make a concerted effort to get decent pics of my car and I now have a cracking camera to do it.
The OH is getting a DA polisher kit in a week or two so i'll let him "test it" ;) on the cupra and no doubt so detailing pics will follow then.
Also just realised there is no pics with the wing mirror covers in candy white, I'll try not to neglect the thread so much!
Well....the car is not parked outside MrNormas house after some sort of engine failure.
Fault code reading as following....
16396/P0012/000018
From Ross-Tech Wiki
Jump to: navigation, search
Contents [hide]
1 16396/P0012/000018 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
1.1 Possible Symptoms
1.2 Possible Causes
1.3 Possible Solutions
Possible Symptoms
Erratic Idle
Possible Causes
Intake Camshaft Adjuster tight/stuck
Intake Camshaft Adjuster faulty
Possible Solutions
Check Intake Camshaft Adjuster
Use Output Test, Meas. Value Blocks (MVB) & Basic Setting
Retrieved from "http://wiki.ross-tech.com/wiki/index.php/16396/P0012/000018"
Few theories being bounced around just now.
Love the car, i thought i was seeing double when i looked at your first post.
How was the ride when lowered 60mm and what was it lowered on?
Jez
The code was cleared and its running a bit better, however it is off the road for fear of engine damage as the most likely cause was oil starvation. The oil strainers in these engines are prone to getting choked up so its coming out and being cleaned and we are putting a new adjuster on.
Watch this space though its getting stipped this evening.
Cool hope this sorts it for you becks;)
It's probably worth me mentioning that when i did a bit of research alot of people were mentioning a faulty camshaft sensor. (Senses the position of the camshaft or somat?) if this is out then it throws up your fault which is why in the possible causes it lists a sticky/worn tensioner.
I am no mechanic so don't take my word for it, but definatly worth bearing it in mind.
Thats the adjuster i'm on about ;)
looking good becks...
car ain't bad neither :p haha kidding
love the white wheels on the blue, suits it perfectly, bet its a pain to keep clean :)
