Do not use the Red Mist.
dont say that i just brought some the other day.lol whats the problem with it??
loving the new stance by the way looks spot on to me and i love the colour of your wheels mate
I'd be too embarrassed to park my car anywhere in the vicinity of yours. Greeneyedmonster.jpg
Normal for spacers to come loose?! I check mine after a couple of weeks (I do very low mileage like you) and they were fine check a year later still fine. I was told NOT to let copper grease get near the bolts as they may cause them to come loose (unlikely but still) only out it on the hubs?
Looks great look froward to seeing the change at the meet then!
 I had torqued them to 20nm as it said on the packaging, they are now at 30nm and been fine since.
 I had torqued them to 20nm as it said on the packaging, they are now at 30nm and been fine since.What's up with the Red Mist then? You used to rave about this stuff so something bad must have happened for you to stop using it
I still use it, have done for many months now and all is ok.
Chemical Guys Blitz - contains wax and sealant. Not a quick detailer but you can layer it to your hearts content whenever you want to freshen things up.Thanks for the info, after all you are the man in the know.
Can you name a good wax based detailer?
	Well, some of us are waiting for the tubular manifold from TSR, i think its in the testing stages atm. B0llocks to the 034 mani
I just wonder if any of you subscribers can help me with this little issue?
http://www.seatcupra.net/forums/showthread.php?t=294829
It's annoying me!
