Couple of deliveries today
Got my intercooler pipework kit for the new setup
Also got my small washer bottle kit too so i can run the pipework down that route
Awaiting map sensor tube and turbo reducer then i can get cracking with it
Still need to bead the end of the pipes (once all ready, size etc)
Then i need an 8mm hose port welding on for the N75 valve
All to come soon though :)
Niiiiice, few pointers for you though before you do it....
Throw away those rubber couplers and clamps and get yourself some decent 4 ply silicone and hefty clamps, if you get the pipework beaded (like I did tonight :D) then you will probs find the rubber couplers will still pop off over the bead.
Don't worry about welding an 8MM take off onto the metal, just get yourself a 8MM hose take of from Revotec around £20 and wack the vacuum piping on that :)
Good luck :D
Good luck :D
Ha that was my next question lol
Dont worry the clamps will be going, ive had bad experiences with crap hose clamps lol
Going to get a load of the t-bolt clamps for this
Are the silicone couplers not very good then?
Beat you to it :)
Keep the clamps for minor things, most likely not car related ;)
T-bolts clamps are good, like mine although after having them pressure tested I see they're not as good as I thought, you need to do them up MEGA tight otherwise you'll find yourself leaking.
The ones that I got in my hose kit were pants, eBay jobby yeah... For what it's worth get yourself some proper 4 ply silicone. I saw it that it was still the cheapest way to do it because the pipework alone cost more than the eBay kit with all the stuff.
Joe
Beat you to it :)
Joe
Hmm spose i shouldnt skimp on it
Ill get some measuring etc done this weekend and find out exactly whats needed and ill get some new hoses etc
Quick question mate
These have to be installed onto the silicone hose and not the alloy pipe yer??
Can i put it on the turbo reducer?
Ive bought a new 51-63mm straight reducer for when i do the pipework so if it will be fine on that then ill do it :)
So, I have been collecting some parts this week to do my new intercooler setup
Heres what i have so far
New intercooler
Its actually quite a beast cant wait to get it on :)
57-63mm reducers for the intercooler
51-63mm reducer for turbo
Forge Map sensor tube
Anyone know what the adaptor plates are for????
T-bolt clamps
Intercooler pipe kit 63mm
Washer bottle
Thats pretty much the lot
Im just waiting delivery of my self sealing hose take off for the N75 valve and ill be fitting it all this weekend :)
Cant wait to finally get rid of the shitty pipework etc i have now!
Cheers guys
Thought they were for different sizes but wasnt sire lol
Well fitting will be this weekend hopefully all will be good!
The 60-68 mm clamps were too small for these pipes so i have another 20 clamps in 67-75mm to go on now
Fitting all the kit tomorrow
Only problem is i havent recieved my self sealing hose take off which seems to be lost in the post :(
Anyone think of a temporary thing untili get one?
Might just have to leave N75 off for few days and run in limp mode
Got cracking today!
Started by removing pretty much everything
Bumper, crash bar etc
The damage to the old intercooler
The goodbye to mr 6.6l
Hello mr 1.2l
Decided while i was there to bin the carbon canister
For those who have done it can you tell me if this is right
Ive removed all the piping, blanked off the hose to tip, blanked off the hose on the throttle body
Then the hard hose that clips into the plastic holder with the 2 fuel lines i have extended down into the wing to vent to amosphere?
Recognise that set up ;) is it off the road for a little? also have you checked clearance on the OEM crash bar?
Lol yours has been a bit of a guide if im honest :)
It will be off the road till its finished yer, few days off work so i should get it done.
Crash bar needs grinding which ill be doing tomorrow now
Any ideas about my post regarding carbon canister? i know you've done away with it on yours
:DLooks very nice bud im just looking into this my self can i just ask what parts you have used
also what are you doing about the plumbing for the n75 could you possible do a little list of bits you have used also were you got your smaller washer bottle to and what lengh map sensor pipe you got thanks
Cars looking great bud:)
Parts really depend on the intercooler you are using but the basic step is buying a mandrel bend pipework kit off ebay (63mm)
http://cgi.ebay.co.uk/2-5-TURBO-INT...CarParts_SM&hash=item5d28a78f1a#ht_1474wt_905
Some pipes will need cutting down in lengths etc
As for the N75 connection
Buy one of these and attatch it to one of the silicone hoses
http://cgi.ebay.co.uk/Silicone-Hose...CarParts_SM&hash=item2eb2f1d1cb#ht_500wt_1156
Smaller washer bottle is just a universal kit on ebay
http://cgi.ebay.co.uk/Universal-12V...arParts_SM&hash=item414b443c40#ht_2044wt_1139
Map sensor tube i bought the longer 240mm length as id rather have too much than too little, after all i can cut it down in size if i need to ;)
Thanks alot bud cant wait to see the rest of pictures of yours make sure you get loads:lol:
Are you changing the pipework from the throttle body to? were you you get the clamps from cheers:):)
I will be mate, redoing the whole lot
Will be taking plenty of pics too ;)
