Looks good, looks like the same IC as mine, certainly alot of chopping to be doneto everything. I moved the radiator back a touch so I didn't have to trim the bumper so much, something you might wanna do if it bothers you.
Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
Any final pictures then
Just spotted this and had a quick flick through.
Looks good Chris! You still attend SaxP meets?
Does anyone have any ideas on how to mount the washer bottle i have
I tried using the OE carbon cannister mount but the bottle wouldnt sit right!
On a brighter note
RR day in March
Nurburgring trip booked for July![]()
Sounds like a plan, ill give that a go this weekend then cheers mate![]()
Berg,
How did you get on, did you try the technique I told you?
Here's a few pics of mine if it helps. The horns that were there were for the alarm, just removed them and the actual horn is in the engine bay tucked away where the old washer bottle once was.
Just drill the one hole and that's that.
I think Robbie mounted his down here too.
Bit of help needed also
Looking at getting some new brakes before i venture to the ring in July
Ive been looking at these Hispec kits
Im unsure what size to buy though
http://www.bigbrakes4u.co.uk/spec-billet-conversion-front-p-441.html
The link above is for 280mm setup so standard size
The 300mm setup alone is £250 more, is it worth the extra just for the extra 20mm?
Keep an eye out for Brembo's second hand - can get them around £800 if not cheaper. 305mm discs and they STOP! Would say I would take you out in mine but you're miles away!
When are you going ring ? I'm going 8th July to the 15th 30 of us are going![]()
