MK3 Ibiza Cupra* K03s Jabbasport* Moving on....
Apr 15, 2009
2,188
Midlands
Any final pictures then
Only as above mate, ill try and take some this weekend once ive gave it a good clean ;)
Just spotted this and had a quick flick through.
Looks good Chris! You still attend SaxP meets?
Cheers Jay
Havent been to any for some time now, im attending the WM RR day in March though should get yourself along ;)
Looks good, looks like the same IC as mine, certainly alot of chopping to be doneto everything. I moved the radiator back a touch so I didn't have to trim the bumper so much, something you might wanna do if it bothers you.
I think it is mate yer
Certainly wasnt a straight fit lol
I wasnt happy about having to cut so much off the bumper but to be fair i managed to get it really neat and tidy so its all good!
I would have moved the rad back but without brackets i couldnt see a way i could do it?
The protruding pipe on the left is now sat further back too so im happy with it all now :)
2,188
Midlands
Does anyone have any ideas on how to mount the washer bottle i have
I tried using the OE carbon cannister mount but the bottle wouldnt sit right!
On a brighter note
RR day in March
Nurburgring trip booked for July :)
joehirth
Rate me up baby
Apr 19, 2010
1,896
Woking, Surrey
www.facebook.com
On a brighter note
RR day in March
Mine was a fiddle, but drilled a hole on the left corner (drivers side) of the bracket, used a cable tie around the washer bottle bracket to pull it back towards the bracket. Then I used another cable tie around the pump itself to pull it downwards and hooked it around the hook type bent metal under where the bottle would be sitting. I can try and get some pics for you if you like mate? Once secured it doesn't move and IMO looks pretty good there :)
Here's a few pics of mine if it helps. The horns that were there were for the alarm, just removed them and the actual horn is in the engine bay tucked away where the old washer bottle once was.
Just drill the one hole and that's that.
I think Robbie mounted his down here too.
Apr 15, 2009
2,188
Midlands
Berg,
How did you get on, did you try the technique I told you?
I did mate and it worked :D
Cheers for the help!
Thats actually a really good place imo, is it fiddly to fill up though?
Apr 15, 2009
2,188
Midlands
Looks a pretty decent place there, keeping the bay clean etc might look into it at a later date
Battery is next to go :D
joehirth
Rate me up baby
Apr 19, 2010
1,896
Woking, Surrey
www.facebook.com
Bit of help needed also
Looking at getting some new brakes before i venture to the ring in July
Ive been looking at these Hispec kits
Im unsure what size to buy though
http://www.bigbrakes4u.co.uk/spec-billet-conversion-front-p-441.html
The link above is for 280mm setup so standard size
The 300mm setup alone is £250 more, is it worth the extra just for the extra 20mm?
Keep an eye out for Brembo's second hand - can get them around £800 if not cheaper. 305mm discs and they STOP! Would say I would take you out in mine but you're miles away!
Apr 15, 2009
2,188
Midlands
Theres just never any for sale mate
Been waiting for a set to come up for months now :cry:
One set did come up but i didnt have the cash unfortunately
And for me id kinda rather spend 800 on the 300mm hi-spec than 800 for second hand brembos but ill see what comes up in the next month or so
