Custom Heat Shield
Hi everyone, a little update here for you.
I've decided to start work on my custom heat shield to help out the Jetex cone a little. Sadly my tin snips haven't turned up so it will be Monday when I receive them most likely and next weekend before I am able to make the proper aluminium version however, here are the pics of the cardboard mock up, I'm very pleased
Version 1. As you can see I had to play around a bit with a larger MAF hole so I'd know where it would sit.
The shield was also too long and high so it was a close shave with the bonnet & hydraulic when closed.
So I set about making V2 now that I know where everything needs to go. I cut the shield down and as you can see it clears the bonnet and hydraulic nicely.
The MAF hole was waaay too big so I closed that up. I'd also not included a bracket to secure the shield on V1 so I added that in too.
The filter was still quite exposed to heat from the turbo in V1 so I added some extra protection.
And here is V2 complete. I will be cutting along the bends when I get my snips and laying it flat against the aluminium sheet to use as a template. The best thing about the design of this shield is that it is all one piece so no rivets or welding needed.
I'm probably going to spray the finished product in matt black to help it blend, I'm sure I'll make a couple of additional mods to it also and depending on how secure it is I might fabricate an extra bracket for the suspension turret mount.
I really enjoyed being creative and making this up, I am hopeful that the metal work will now be the easy part.
