Tell
Tell
Hello guys, i have a problem with my multimedia on my Seat Leon 5F with factory MSTD_EU_SE_P2313, MU Version 0132, i tried to update the software version with rar file from mibsolution.one (MSTD_EU_SE_P5310 MU0480), everything was going well on the update but when 3 files left to overwrite all of sudden multimedia went black but not completly black and it stays like that all the time, when i try to restart it with holding power button it goes completply black and come with power again but still black and i can't do anything now, i checked it with obd11 and there is communication with 5F unit which i think is a good sign. i need your help if you have any solution...i just want to make it like it was before no need to update it, thank you in advance
Yes you need to seek help on the mib2 firmware thread
You are told n th times not to jump firmware trains. You can't as per above.
This thread is solely map files not firmware files. I believe you can open these units up and short a couple of pins out which de bricks it. You'll find instructions on the Internet. @East Yorkshire Retrofits provides a service of train jumping and has sorted peoples units out in the past where they have messed them up. Unfortunately the likes of Mr Fix with YouTube videos leads people into going up a dead-end.
Anyhow and conversation on mib2 firmware should be on that part of the board. The unit are like early computer so you write across the boot firmware code with the wrong train.
It’s likely you need to change the long coding, alter the skin/skinnings (then reboot) until it boots. This is a pretty common “issue” when updating MIB1
Reactions: ak1_
Tell
What about this 😉 SeatCupra thread
The penny dropped so it's allowed here. I think you are probably updating to the 2023 maps.
Reactions: ak1_ and DaveS
Oct 5, 2025
It worked, Thank you very much. I appreciate it. I did the coding how it was mentioned above and then restarted the multimedia by holding power + menu and it continued the update successfully
Tell
You got @East Yorkshire Retrofits to thank for that. They use to sell the software but Vag prevented them since one presumes they wanted to make it dealer visits only. Probably some note that was published with the 480 mib1 firmware at the time which said if an update of older firmware then do this which they put in their advert now deleted.
Vag changed the long string for reason which meant you had to do it to make it work. I remember it came up on their web site before they took the page down but we had never found it an issue on the navigation thread with people updating to the mib1 2023 maps but evident by that post it does effect some people as you found.
Reactions: ak1_
We still perform software updates here at the workshop. We do not distribute software files themselves
The available skins changed, meaning the new software is trying to launch with a skin that doesn’t exist and is getting stuck
Reactions: Tell
