EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Awesome pics Darren. Here are a few more of yours that I took........
D.K
LCR 225
Oct 24, 2007
6,408
se london
Started mocking up for a bigger heat shield, for those of you familiar with an LCR engine bay this one will sit to the left of the relay box by the TIP meaning the MAF will be on the "Cold side"
mk1 template on top
Pictures are a bit poor but the mk1 is sitting infront of the mk2
It needs a bit of trimming to get the fit right then it'll be cut out of the same material as the mk1 and then when I'm happy with the fit it'll be wrapped in carbon fibre.
D.K
LCR 225
Oct 24, 2007
6,408
se london
Fitted the template this morning
It fitted pretty well the first time, only very small adjustments were needed, once it was right I cut the pieces out of the board and glued them together
Then another test fit and some more minor adjustments
And finally cut and fitted the base
It's now all glued together, next stage will be to wrap it in carbon which will make it nice an strong.
Also whilst we were out today I noticed the oil temp was getting a bit high,
I wasn't really pushing it that hard, the temp sensor is in the oil filter housing unit and I'm running Fusch Titan race pro 5W40 whioch was changed in Feb this year.
I might look at getting an oil cooler soon
D.K
LCR 225
Oct 24, 2007
6,408
se london
The heatshield looks good, what have you made it out of?
Thanks mate :) It's some kind of high density foam board, not sure what its proper name is, the board itself is very strong.
Oil cooler that bad boy, your as much of a hooligan as me ;) I will get you a shopping list of parts!!!
I think I'll have to start collecting the bits for this soon.
Nice work on the heatsheild.... fancy making me one.... pretty please :)
I might have a smaller Jabba size one going spare soon ;)
