Well, when I last compared the boost plots of my LCR with those from an Ibiza Cupra R, the difference was 1psi... the difference in power almost 35bhp... the difference... 1 car has a K03 turbo, the other a K04 (standard mapping), so the E05 should be producing more again!! It's not all just about the boost pressure...Originally posted by Glenn
FFS, they're spot on for the boost he's running at that RPM. The idea that the car is bad if it's 240bhp and good if it's 250bhp is utter sh*t. The question should be : "Is the car as fast as I want it to be?", not "Does it give me a certain number on a bit of paper?".
Andy.Originally posted by m0rk
Just for stirring & conversation...
But would it not be in Jabba's interests to do as good a job as possible with a Turbo that's a complete unknown to them, that they've had little time with?
There's probably insufficient data freely available as well.
Maybe there isn't a Dimsport file available just yet either
I knew I could talk you around!!Originally posted by Shock_Xe
Bugger it ima go for injectors and 4bar fpr before Jabba, I want to be safe and know i hgave done everything i can and dont want that niggly thought of "What if i had done....."
Originally posted by Dormouse
P.S. What's car length got to do with it?
Originally posted by Nippa
So, in other words, and to cut this very long story considerably shorter...
E-05's being naff on Ibiza's is not really the fault of the E-05.. But quite probably the downpipe arrangement Ibiza's have?
So perhaps still a good turbo for most other VAG 1.8T's which are not held back with crap downpipes?![]()
I await opinions![]()
