Be good to see what you thing of these as I'm getting a set soon well the ones that damp and are height adjustable
I've had a couple of rides in LCRs with these fitted and I liked them a lot. Thet were a little stiffer than OE but nothing bad at all, if anything they felt more comfortable. I that think if I did get damping adjustables, I'd have them set to the same firmness as these.
God that was quick, bet you cant wait to get them fitted now! Not sure about the black disk as i didn't fit mine, I'm adjusting them the weekend so i can have a look for you then if you want?
That would be great, Doc. Don't go out of your way or anything but if you can slide a finger between the coils of the spring and push up the green sleeve a little, you should be able to see if there's a black plastic disc under it. The sleeve is easily pushed back down again
brown pants moment defo!
